March 18, 2025, 05:50:05 PM
Author Topic: Procharged D1SC LS2 RX8 Build Ronin 8.8  (Read 45341 times)
Offline 1320king
Re: Procharged D1SC LS2 RX8 Build Ronin 8.8
« Reply #105 on: March 18, 2016, 06:06:09 PM »
Going to be awesome man! The crops in my area are all dried up  :( , and have been for a wile.
Offline Coda734
« Reply #106 on: March 18, 2016, 07:05:30 PM »
Offline Tictakman
« Reply #107 on: March 18, 2016, 07:10:43 PM »
I want to warn you about that horizontal flow IC... you will see a pressure drop issue with the procharger and might only boost 2/4lbs.  I had to change to a vertical flow which I got from treadstone performance and it solved my boost issue.
Zak
Offline Coda734
« Reply #108 on: March 18, 2016, 07:25:52 PM »
Thats not good. I picked up the IC for 100$ but don't want to have to change everything if its uneffecient. Given our time frame, I can't afford to pick up a new IC and wait for international shipping. I will try to sort that out though. May have to change up after our bond is finished.
Thanks for the tip
Offline Jordan Innovations
    • Jordan Innovations
« Reply #109 on: March 19, 2016, 10:02:08 PM »
I agree, you'll want to go vertical flow if you ever want to make any real power.  Treadstone makes a couple decent ones for mid-power cars, but Bel cores are top-notch if you want to make your own.
Offline Coda734
« Reply #110 on: March 20, 2016, 01:36:36 PM »
I'll have to swap it after our deadline. We have less then 3 weeks left on the table, swapping the IC set up may be more difficult then necessary right now. I'll need to build my trans and forge my motor if I want to run higher then 8 psi on my compression. This is a daily driver, so the 600rwhp goal I have right now is plenty.
The intake is rated to 800, but if its going to rob power I will swap it regardless.
Offline Coda734
« Reply #111 on: March 20, 2016, 01:40:45 PM »
Offline Coda734
« Reply #112 on: March 30, 2016, 01:14:16 PM »
Just some odds and ends getting tydied up.
Car will be back in 10 days!!
Have about 1500$ worth of minor but critical parts on their way to Sheldon.
Corvette accessory drive for the procharger, bunch of AN fittings for fuel, tubing and silicone couplers for the IC
Offline Coda734
« Reply #113 on: March 31, 2016, 07:16:53 PM »
ABS mounted, new flywheel mounted, monster twin disc pr0n, carbon fiber pr0n :)
Offline Coda734
« Reply #114 on: April 03, 2016, 05:52:07 PM »
Read diff solid mounted and 3.9 FD TT Auto Ring & Pinion installed until 8.8 from Ronin arrives
Brake lines ran, just need to be flared. All sub frames should be mounted tonight. Car is starting to look like it will meet the deadline! Sheldon is fuckin killing it!
« Last Edit: April 04, 2016, 04:03:42 PM by Coda734 »
Offline Coda734
« Reply #115 on: April 04, 2016, 03:49:33 PM »
-Mustang rack mounts braced
-Brake lines need to be flared
-Clutch pedal is welded and reinforced (common problem on these)
-Master Cyl installed
-Pedal installed
-Throttle cable ran
-Rear subframe reinstalled
Sheldon plans on doing the Engine and Trans tonight.
I'm driving out there tomorrow to drop off a few more parts. Vette Alternator, PS pump, and bracket.
[attachimg=1][attachimg=2][attachimg=3][attachimg=4]
« Last Edit: April 04, 2016, 04:03:52 PM by Coda734 »
Offline Coda734
« Reply #116 on: April 07, 2016, 08:33:25 AM »
Reassembly at this point
Smooth sailing :)
Sick shot of Sheldon cutting out intercooler brackets
Offline Coda734
« Reply #117 on: April 12, 2016, 10:18:02 AM »
So obviously no car yet.
We extended the bond until the end of April but hope to have the car back this Sunday.
Ronin 8.8 should be shipping out sometime this week or next, which means the car will come home shortly and go right back up to him for that install.
[attachimg=1][attachimg=2][attachimg=3][attachimg=4][attachimg=5][attachimg=6]
Offline Stubbs
« Reply #118 on: April 12, 2016, 08:25:55 PM »
I'm interested to see how that trans mount holds up.  The sheet metal on the RX8 trans tunnel is super thin. It'll give you a lot more room for exhaust though.
Offline Coda734
« Reply #119 on: April 13, 2016, 07:52:02 PM »
There is a 2x3" plate on the opposite side its connected to.
He ran the same brace last year and it held up perfectly through potholes that he thought bent his rim.
