March 16, 2025, 04:45:13 AM
Author Topic: Help!!! installing engine and trans clearance issue  (Read 2752 times)
Offline Hamilton1002
« on: August 02, 2014, 03:52:39 PM »
I have a 88 rx7 putting a sbc with a t5 trans I bought the basic kit from
Grannys and I'm trying to get the engine in with the trans connected
And I can't get the motor to the correct position it looks like the bottom of
The bell housing is hitting the cross member what am I doing wrong
Any tips would be appreciated
Offline texfc
Re: Help!!! installing engine and trans clearance issue
« Reply #1 on: August 02, 2014, 04:51:16 PM »
Is the tail housing of the T5 hitting the floor as it goes in?  You may need to jack the car up some.  Also make sure you have the distributor off when you put it in.
1989 GTU - 355 SBC - WC T5 - TII rear - build thread http://www.norotors.com/index.php?topic=354.msg3811#msg3811
2005 Tacoma 4x4 - daily driver
1966 Mooney M20E upgraded to 201
« Reply #2 on: August 02, 2014, 06:02:15 PM »
Not hitting, I got all that its like the bellhousing is hitting the firewall and the cross member and won't go into place
Offline DDv8
« Reply #3 on: August 02, 2014, 08:02:51 PM »
What bell are you using?
 A tilted t5's hydraulic slave bracket looks like it would be to wide to fit between the k frame rear mounts.
 I just checked both a 11-12  and 10.5 straight up housing and both clear with a lot of room to spare.
I'll post picts when I get to my other computer
DD
86fc old school 327, T5, converting to 8.8 tbird
« Reply #4 on: August 02, 2014, 08:24:44 PM »
I took the trans off the bellhousing and it fits better
now it just looks like the oil pan is hitting in front and back
« Reply #5 on: August 02, 2014, 08:28:49 PM »
Shouldn't be hitting in the back, but the front of the pan usually needs to be clearanced or notched to clear the steering rack, and sometimes the mount itself.
« Reply #6 on: August 02, 2014, 08:31:57 PM »
Does it matter if I got the convertible I was reading somewhere that it does
And that I should remove the cross member and weld a new one in
Offline jim3
« Reply #7 on: August 03, 2014, 09:25:44 PM »
Check out bikedad's build thread.  He's been there, done that, and beyond.  Use the front holes in the cradle, clearance the pan.
You can make a barn door fly with enough horsepower.
Retirement at last.  Wife's not happy, I bought a '66 Rustang instead of paying off my F150.
Offline texfc
« Reply #8 on: August 03, 2014, 10:31:46 PM »
Are you using the old style straight up bellhousing or the f body tilted bellhousing?  I have the Granny's oil pan and still had to shim up the motor mounts with a few washers to keep it off the mount.  I wouldn't be surprised if they shipped you the wrong transmission cross member, Grant has shipped me a few wrong parts, but he always made it right, just took extra time.
Offline bikedad
« Reply #9 on: August 04, 2014, 10:10:15 AM »
You can look here for some information.
http://www.norotors.com/index.php?topic=86.0
I had to clearance the front of the oil pan to sit over the sway bar.
Don Teifke  :drive:
[smg id=8489]
-----John Wayne-----
