I should also mention up front that I had two key helpers in that my folks just happened to be visiting from California. They booked the trip months prior and it just worked out that they landed the day before escrow closed. I honestly felt a little guilty about how hard we worked on their “vacation” since they’re in their 70s. Anyways, they love me.
We asked about the ability to gain access to the home before closure but that was a no (for liability reasons). Instead I was at Home Depot in Hilo by 7:30 am on Oct 15 to rent a floor machine.
There are basically two versions of rental floor machine available, floor maintainer and floor grinder
https://www.homedepot.com/tool-truck-rental/Floor-Maintainer/01278A/https://www.homedepot.com/tool-truck-rental/Concrete-Grinder-10/50200-HD/index.htmlIf you go for the the 17" spinning "floor maintainer" you can either can put sanding pads on (think scotch brite for floors, my approach last time), or you can rent a dimabrush which is a step heavier and uses diamond impregnated paddles as an abrasive media.
https://www.homedepot.com/tool-truck-rental/Coating-Removal-Disc-7/12569/index.htmlWith some 2,000 square feet of floor to do I was planning on the dimabrush approach until I discovered my Home Depot's rental floor maintainers didn't include a vaccum hookup. (Note, this isn’t true for all, I did the floor maintainer approach w/ shop vac hookup last time. Check your local rental supply.)
Lack of a vacuum hookup was a deal breaker for me so I jumped up a step gnarlier and instead rented the 10" floor grinder. It weights something like 160 lbs so plan on a friend to help load and unload. The business end is not screwing around.
At the end of the day I was glad I went big since my floor was pretty gross in a bunch of places. Here’s the old paint booth leftover I mentioned that’s flaking off about 1/8" thick.
Pro tip number 1. The technique for the floor grinder is to swing it back and forth, not march in straight lines (a mowing the lawn approach leaves more grooves).
Pro tip number 2. Your shop vac is gonna take a bearing. Plan on two filters so you can knock the dust out every 5 minutes or so. The filter will clog with the finest dust ever. It's fluffy, but heavy if that makes any sense at all. Best guess I took 150-200 lbs out of my floor. It sounds like a lot but it was maybe 4-5 trash bags partly filled (but heavy enough to be in danger if breaking).
The other cool thing about the grinder is that it really highlights areas that aren't quite as flat in the floor. You can visually see where you've been and it's kind satisfying to shave on the seam just a bit more and know that the floor is now flatter than it was.
Here’s the texture it leaves:
By the way, while I was grinding my father was filling a mess of small holes and some hairline cracks.
There may be better products available but Home Depot had a Quickcrete product available that we took a chance on and it seemed fine.
https://www.homedepot.com/p/Quikrete-1-Qt-Concrete-Crack-Sealant-864000/100318507Got a little nervous when it started raining outside. Even with a shop vac attached the grinding process puts out enough dust you’ll want some airflow. Didn’t get things TOOO wet, so we’ll just have to risk it picking up some moisture prior to paint.
When you're done grinding (which by the way takes about an hour per 200 sqft in my experience) everything is covered in fine white dust.
Go after it with your shop vac and a floor attachment and suddenly you can really see what’s going on. After a decent vac'ing I become painfully aware of the low spots you missed.
Oh and regardless of technique, you're still gonna leave swirl looking grooves as you change direction with the machine. Generally barely deep enough to catch a fingernail on but you can see them.
If you care, you might need to figure out a multistage grinding process. There is a process to dial in flatness of the grinding head—which I did… you basically set the grinder down, grind briefly and be sure you carve an even circle--but adjustments only goes so far when the machine gets moving with momentum.
After vacuuming and see what was up, I wasn’t stoked on having “missed spots” and since my floor was so filthy I wanted to give the Hellfire every chance I could of sticking. Soooo... Took a second pass with the grinder. All in I worked a 19 hour day, a solid 14 of which was on the grinder.
Oh yeah, don’t forget the gloves, then don’t forget the bandaids when you get blisters anyways. Better yet don’t try to do 2,000 square feet in a day. That said, the rental grinder runs ~$200 a day so if you gotta hustle, you gotta hustle, just be ready for it.
That's how I ended day 1 (Tuesday Oct 15) with Saturday being the move day.
