March 17, 2025, 09:40:30 PM
Author Topic: new ford taurus fan issue  (Read 4522 times)
Offline overkill-lt1
  • your turbo isn't big enough riceboy
« on: June 22, 2014, 01:57:29 PM »
ok guys  last year i put a new motor in my ford taurus fan and then sent it to the paint shop. so this pasty week i had it out and when the fan comes on, my car starts  hunting for and idle and will eventually stall out. could this new motor be backfeeding somehow or should i loom elsewhere. i unhook the fan car gets to temp and it idles  jsut fine and steady. plug the fan, start it up and like clockwork it starts to hunt.  thanks
In the 10's Bitch, I'am not scared of your honda !
Offline scuter83
Re: new ford taurus fan issue
« Reply #1 on: June 22, 2014, 02:19:12 PM »
Is your intake right behind your fan?  Any chance you are messing up the airflow into your MAF?
« Reply #2 on: June 22, 2014, 07:03:42 PM »
Low amp output from alternator?
Offline cool
« Reply #3 on: June 22, 2014, 09:09:30 PM »
Check your battery too.
« Reply #4 on: June 23, 2014, 09:55:34 AM »
i have it wrapped. i will log and see if it spiking or not
thanks
« Reply #5 on: June 23, 2014, 09:55:56 AM »
i will check both of these out
Offline Ey8s
  • Newbie
  • Stumbling blocks represent learning opportunities
« Reply #6 on: June 23, 2014, 12:46:20 PM »
I'm currently running a two speed tbird 4.6 fan, before that it was a single speed mark vii fan.
they take A TON of amps to get going.  my single speed mk vii had an 80 amp surge when it came on.
I can see where that type of draw could mess with your ecm, especially if you don't have a high amp alternator (120 or better) and/or have your fan wired as a single speed/high setup.
this is the relay setup I'm running now (just food for thought):
http://www.hollisterroad.com/proddetail.asp?prod=MarkVIII
« Last Edit: June 23, 2014, 01:01:09 PM by Ey8s »
Current Project -1985 GSL - FC subframe/TII brakes/LQ4-LS6/4L80E/Explorer 8.8/Home fab torque arm
Offline clocker
« Reply #7 on: July 01, 2014, 07:41:50 PM »
I've run all my fans (Taurus, Volvo and currently, 18" Lincoln) through a Volvo fan relay and a 30A fuse.
Never blown the fuse, fans work great in both speeds.
I keep hearing about the massive starting current draw of these fans and wonder why it's not tripping my (theoretically) undersized fuse.
« Reply #8 on: July 01, 2014, 08:02:02 PM »
The starting amps get higher as the fan motor wears out.
Offline clocker
« Reply #9 on: July 01, 2014, 08:43:59 PM »
The op said he installed a new motor recently.
« Reply #10 on: July 01, 2014, 09:31:42 PM »
Yes that's true. I have no experience directly but I have read that some aftermarket replacement fan motors are "sub par" and suck a lot of amps on start up as well.
80 amps is a lot to get a fan going.. Too much in my opinion and requires some investigation.
Here is some info on typical AMP draw from Taurus and Mark VIII fans.
http://www.thehollisterroadcompany.com/TaurusMarkVIIIrelay.html
I have 2 SPAL 11 inch fans, each on a 30 amp fuse with no problems.
« Last Edit: July 01, 2014, 09:42:28 PM by largeorangefont »
Offline Ey8s
  • Newbie
« Reply #11 on: July 28, 2014, 09:13:45 PM »
the mark viii fan was pulled from a JY so there is probably merit to the idea of increased resistance with age/use.
« Reply #12 on: July 28, 2014, 09:29:14 PM »
My Firebird had a new Mark VIII fan, and with no fan controller, it would pull between 80-86 amps on startup, and about half of that continuous.
