And now to discuss what I believe to be one of the more complicated portions of the project. The engine mounts!
Traditionally, it seems most manufactures who make kits for the SR-20 / KA20 engine swaps (closest example I could find to the F20C since they are both 4cyl engine which mount far back) make weld in mounts which tie into the frame rails and pick up the engine mounts well behind the original chassis cross member mounts. The reason for this, although obvious I want to state it, is because the whole engine is now behind the stock engine cradle mounting points, so therefor the engine mounts are going to be even further behind. Here is an example of the most popular "Mckinney" SR-20 swap cradle (he has removed the old engine mount points from the cross member):
I'm am currently not a huge fan of this setup. Probably mostly because I would rather have a bolt-in solution that uses the factory engine cradle. From what I can see, the F20 must have engine mount points on the block which are further forward when comparing to the SR-20 / KA24 which gives me the idea that I might be able to design mounts that just "bridge" forward the required distance to pick up the stock engine cradle.... clear as mud, right?
So here are the measurements that I'll be working with for starters... I'll be making up some parts in 3D CAD to post up later this week to see what you all think.
Stock engine cradle angle... I'll assume it's 45*:
The F20C engine comes from the factory in the S2000 mounted at a slight angle to help with hood clearance. I am maintaining that angle which appears to be about 15* off vertical.
And this is how far my replacement "bridge" mount will have to span... from the front bolt it's ~5-1/2 - 6". No easy feat, but I do have a design in mind (sorry about the blurry picture, it was an awkward position and I was all hopped up on coffee):
I have already posted this picture, but now you need to see it again to see the factory engine cradle mount points, the tilt of the engine and the aluminum mounts (which I will be re-designing/replacing):
Is this making sense to anyone? Hopefully my 3D CAD mock-up will better help relay my ideas...
