Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Search
Recent Posts
Gallery
Search
Stats
Login
Register
This topic
This board
Entire forum
Google
April 01, 2025, 02:23:06 AM
Technical Information
Drivetrain
Ford 8.8 IRS Diff Rebuild (DIY)
Add to Reputation:
I agree
I disagree
Comment:
« previous
next »
Print
Pages:
1
2
Author
Topic: Ford 8.8 IRS Diff Rebuild (DIY) (Read 52277 times)
theantirotor
Top Fuel
View Gallery
Re: Ford 8.8 IRS Diff Rebuild (DIY)
Reply #15 on:
May 27, 2015, 02:59:01 PM »
What is the purpose of the case spreader?
Logged
largeorangefont
Top Fuel
I steer with the gas pedal.
View Gallery
Reply #16 on:
May 27, 2015, 03:52:08 PM »
Spreads the case so you can get the carrier shims in without messing up the housing.
Logged
Sell it to spacevomit. He'll finish it.
osburn383
Pre-Staging
View Gallery
Reply #17 on:
June 27, 2015, 07:35:17 PM »
Thanks for doing the great write up.
Im rebuilding mine right now.
What do you think if these mesh patterns.
Im thinking i may need to reduce the pinon shim.
Last Edit: June 27, 2015, 07:52:09 PM by osburn383
Logged
Schitzo
In The Bleach Box
View Gallery
Reply #18 on:
March 27, 2016, 11:29:51 AM »
Re-uploaded the pics.
Logged
Gunnytron
Top Fuel
View Gallery
Reply #19 on:
February 01, 2020, 09:36:14 AM »
Two questions (answered my own questions).
What is "the desired carrier shim preload"? - 0.006 each side. This the amount taken out at the beginning of the process.
How did you know the Pinion shim is the correct thickness? - use a tool or look at the gear pattern.
Last Edit: July 01, 2020, 03:11:01 PM by Gunnytron
Logged
Print
Pages:
1
2
« previous
next »
Drivetrain
Jump to:
=> Drivetrain
