So I have had a small issue since I swapped the car. Because I am using the automatic PCM, it is constantly reading 158 mph because it is looking for the speed signal from the trans via CANBUS. When I first swapped this motor in, I couldn't find any solution to the problem. I then found a thread where a guy wired in a TCM and got it to communicate with the E38 PCM.
More details in this separate thread:
http://www.norotors.com/index.php?topic=25871.0So right now it works from the standpoint of it will read "0" mph. This has greatly improved my low speed drivabilty even though it isn't reading any speed. I am working on getting with my tuner to turn off all the codes it is throwing because it is looking for a bunch of automatic trans things... It is causing some error that it is cutting throttle when I get on it. I hope turning off all these codes will solve that as well.
I had some time this weekend to repaint a couple of the interior panels and get rid of the much loved (
) green under the hood.
