ABS update - The ABS light is still coming on occasionally, I am not sure why. It will come on when I turn the car on and if i turn it off, it will be off. Not sure what is going on here....
On to some less frustrated updates... I finally had a chance to take care of some little things that I have been planning for some time.
First, I installed my Racingbeat dual-tip I have had for some time. I am super impressed with the sound, it is much quieter than my Vibrant with almost zero drone. It makes the car much more pleasant to drive on a day to day basis. I still have my vibrant setup so I can switch them out if I need slightly more power. It is hard to tell how my HP I lost with the 3" vs the 3.5...
Next I worked on my trunk carpet. Because I have the sub and no spare tire (substituted for a pump and fix-a-flat) I needed something with some strength and that I could cat around my sub. I used 1/4" fiber-board with a piano hing down the center so I can remove it. I will be covering this with carpet and backing with foam. I am pretty happy with the way it turned out.
Cardboard Template:
Fiber-board with hing installed:
Next up was something that might seem insignificant but I hated the look of the stock bin lids. Instead of just recovering them, I decided to make new, smooth one's and cover them in suede to match my bins.
First I traced the bin lid and made a template and cut it out and sanded it on my disc sander. Fitment was decent but not perfect so I made some adjustments on the next one. I got it perfect and then routed a lip. I used nutserts to make sure I have a good/strong connection point as MDF doesn't take screws very well.
Final fitment is pretty spot on.
Next up, cover them in suede once I get carpet so i can do it all at once. Then i will have my wife make two suede handles/pulls for the top.
