Below is what i ordered from McMaster on the standoffs. The longer one's are for the cluster hood, the shorter are for the headlight and cruise switches:
98952A147 Aluminum Male-Female Threaded Hex Standoff 8 mm Hex Size, 14 mm Length, M5 Thread Size
98952A138 Aluminum Male-Female Threaded Hex Standoff 8 mm Hex Size, 8 mm Length, M5 Thread Size
92005A320 Steel Phillips Rounded Head Screw M5 x 0.8 mm Thread, 10 mm Long, Packs of 100
Couple rounds of filler on the shaved holes:
I also starting to make a mount for the gauges. I am using 1/2 x 1/8 steel bar. I will be threading a M5 bolt through the back of the gauge and then attaching with a nut to the bars.
