My vibration is more low speed, low load.
I think it may be due to some driveline angle issues as well, but the side to side angle instead of up and down.
I'm using the factory rubber diff bushings (f&r) and delrin subframe bushings. The trans crossmember is using an energy suspension poly mount, as well as the engine.
I measured 86.5 degrees on the yoke spline face on the trans, and 85 on the face of the pinion.
I'd like to poke around your car anyway, as they're both set up for road racing / autox. Let me know when you're free, maybe we can get some stuff sorted out.
