March 18, 2025, 08:55:57 AM
Author Topic: Digital_hoon's Built LS7, 8.8 IRS, T56 Magnum - MB FD  (Read 24900 times)
Offline digital_hoon
« on: April 10, 2014, 10:04:24 PM »
After being a member of the forum for awhile, I figured I might as well start a build thread before I start forgetting stuff.
A little introduction since I don't have many posts. I bought my 93 touring RX-7 locally (SE Michigan) about 2 years ago. Its a 93 chassis with 53,xxx miles and a fresh respray from 2008 in the original lead based montego blue. I had bought it from a rotary junky (He has a red 20b, black R1, mint FC, and some parts cars). It had a 94 powertrain with around 20,000 original miles. It was a good motor, but I was already having dreams of torque after seeing the huge community of v8 swaps. Fast forward some, I was enjoying the rotary and even started making some plans to build it.
Here's what she looked like when I bought her. Only a HKS downpipe/cat-back.
[attach=1]
[attach=2]
It wasn't long before I started with some little stuff. Some plasti-dipped wheels and R1 lip.
[attach=3]
Then came the wheels I always wanted. My mint 2nd hand Volk TE37's along with Koni yellows and eibach springs.
[attach=4]
[attach=5]
Then, I came across a second hand, but still new bare LS7 block. With the bare block only being $1400 and having access to a ton a LS knowledge/parts being near Detroit - I couldn't resist. If I was going to swap a v8 in, it might as be the big guy. So I bought LS7 block last May. Since then, I started piecing together and planning my engine build. I had accumulated some rotary related parts in the midst of planning for that build, so I've sold all of that off to help pay for the LS7 stuff.
[attach=6]
I couldn't resist seeing how it would look as a table.
[attach=7]
After endless hours browsing the internet for deals on parts, I went through a couple stages. I was first planning on going with a stock rotating assembly. Then it went to forged pistons only, finally ending on forged rods/pistons and stock crank. This wasn't necessarily a bad thing as I found a deal on stock pistons/rods which I ended up selling for a profit. I chose Billy Briggs at MotorCity Speed to build my motor after recommendations from some friends. He was a huge help in helping to decide parts and was more than happy to answer all my questions. I went with a decent size cam setup (custom grind), JE Pistons, Compstar rods, and had the block and heads studded. New exhaust valves and guides on the used LS7 heads I had bought, along with PAC dual valve springs for peace of mind.
[attach=8]
[attach=9]
Fast forward to the present, I picked up my built, wetsump LS7 longblock 2 days ago and started pulling apart the rotary motor this past Sunday. I found a local buyer for the 13B, which payed the final bill for the motor. While piecing together the motor, I was able to source a 8.8 IRS from an 03 Cobra and joined in on 1 of the group buys for the Samberg cooling setup. As it sits today I have my longblock, rear end, and radiator setup. The 13b is halfway out (should be out this weekend) and I've got plenty more parts to accumulate. :)
[attach=10]
The next items for purchase are a T56 magnum transmission, and Mcleod RXT twin disc clutch. After I can get the engine/tranny mated - I'll be on to a Samberg subframe and rear cradle. Then, I only have...
fuel
spark
headers/exhaust (JTR or Spoolin, undecided)
ECU (still undecided...stock, Holley)
driveshaft
axles
and a million other little things I try not to think about.
It'll be awhile before its done, but it should be well worth it in the end. I'm sure I'll have plenty of questions along the way, a lot of which you guys have already answered. I'll post some more picture I've gathered later on.
 - Cody
« Last Edit: May 14, 2014, 12:04:32 PM by digital_hoon »
www.C2renders.com  - Digital marketing assets tailored to the automotive aftermarket.
'07 RS4
'93 Montego Blue FD - Mid-operation
Re: Built LS7, 8.8 IRS, T56 Magnum - MB FD
« Reply #1 on: April 10, 2014, 10:15:33 PM »
Some more pics to keep things interesting.
Random order...
Years of lust brought me to a random post at the club where I got these for $2,300 shipped from Seattle to Detroit, with tires! 285 rears, none the less.
[attach=1]
Piston porn
[attach=2]
More engine porn
[attach=3]
The 8.8 Rear
[attach=4]
Shining down on my beauty...
[attach=5]
Lastly...the reason the engine build/swap slowed down. 2007 Audi RS4 I picked up in November.
[attach=6]
'07 RS4
« Reply #2 on: April 10, 2014, 10:21:35 PM »
Beautiful!
« Reply #3 on: April 10, 2014, 10:28:30 PM »
Thanks!
Before...
[attach=1]
Current...
[attach=2]
'07 RS4
Offline quinns
« Reply #4 on: April 11, 2014, 01:11:55 AM »
I'll be watching this build that motor is going to be NASTY!!! :o
1997.5 Hummer H1
2006 Hummer H2 SUT
Offline karsty
« Reply #5 on: April 11, 2014, 04:09:38 PM »
I completely hate you now lol.  My two favorite things...an LS7 FD and a B7 Audi RS4.  I'm torn between swapping my all original 19k mile R1 or buying another RS4(had one before but sold it and now regret doing so).  I'm not baller like you so I can't have both.
I will be keeping a close eye on this buid as well!
Offline scuter83
« Reply #6 on: April 11, 2014, 05:13:57 PM »
Looks good.  Should make for a really fun ride when done.  I live in Ann Arbor, MI.  Where about in SE Mi are you?
« Reply #7 on: April 11, 2014, 05:53:23 PM »
Did you balance the rotating assembly?  The ls7 crank has a bobweight for the ti rods and cast pistons.  Forged rods and pistons add a ton of weight.  The crank would need a lot of mallory added to balance.  Mallory is expensive as hell...just curious.
Nothing wrong with the choice, but from what I gather the cost of balancing often makes up the difference of starting with an aftermarket forged crank.
« Reply #8 on: April 11, 2014, 07:11:23 PM »
haha! Thanks man! Probably not as baller as you think though. The RS4 has definitely slowed down the swap, but it puts a smile on my face every time I drive it. You can have both, be like me and just take a year to get the engine pieced together and built. lol. What year/color RS4 did you have?
Thanks! I'm in Royal Oak. You ever make it down towards Woodward?
Yah, it had to have a lot of mallory put in it, which I didn't think about at first. Ended up being like $160 extra for the material but I picked up the stock crank which is already forged for $425 so it was still worth it imo.
'07 RS4
Offline Still_Ridin_Clean
« Reply #9 on: April 12, 2014, 11:27:23 PM »
Subscribed :) nice build
Offline XLR8
« Reply #10 on: April 12, 2014, 11:40:48 PM »
Looking a lot like my build and equally exciting.   MB as well. :)
94 MB Base...416 LS3 Stroker......Build Thread
« Reply #11 on: April 13, 2014, 03:39:45 PM »
Thanks!
I've scanned through you build thread as well, good stuff! Should be very similar
'07 RS4
« Reply #12 on: April 13, 2014, 03:47:57 PM »
Couple updates. Got the engine ready to be pulled (I think). Those bolts for the aluminum brace alongside the transmission were a bitch!
Also got the exhaust, seats, and rear bins out. Harness is unhooked at both ends so I'll probably wait until I pull the motor to get it out. Did you guys pull it through the interior or engine bay? Seems like it's gonna be a pain either way.
Here's pics of the current state. I'm probably going to get some black carpet to replace this beat up tan. I've got a nice replacement for that steering wheel as well. :)
[attach=1]
[attach=2]
'07 RS4
Offline 1320king
« Reply #13 on: April 13, 2014, 06:52:59 PM »
awesome! looks great man, LOVE the rs4
Offline scuter83
« Reply #14 on: April 13, 2014, 08:47:50 PM »
[/quote]
I've been out to Woodward before, but my car isn't done.  My DD isn't the best woodware car, better for the dirt (wrx).  There is a yellow FD with an LQ9 out by you.  When I get mine on the street maybe I'll have to stop by....
