March 18, 2025, 04:14:57 AM
Author Topic: Michelle's 2005 RX8 "All Stock Systems Work Swap"  (Read 38682 times)
Offline mobythevan
Re: Michelle's 2005 RX8 "All Stock Systems Work Swap"
« Reply #60 on: April 02, 2014, 10:49:53 AM »
hahaha at the vid ^^^^^
OK, just because LSJ was mentioned a lot, here is a pic of the major problem with that setup:
Would require cutting off the end of the SC and welding a 180 degree bend I guess.  Or a 90 at least depending on room at the firewall.
==86 FC Ronin Tri-Point Widebody 5.3, Powerglide, 8.8 TASA, MegaSquirt 3, S475, 16psi, E85==
    mobythevan1 on instagram
    First Turbo Drive: https://www.norotors.com/index.php?topic=5271.msg245290#msg245290
« Reply #61 on: April 02, 2014, 10:59:28 AM »
Don't laugh, but just to throw something weird in the mix, how about a 1st gen Kia Sportage engine? It's a RWD config. Mazda FE-DOHC 2.0l.
Offline mobythevan
« Reply #62 on: April 28, 2014, 05:15:59 PM »
We have put 4k miles on this car now since purchase.  It will die eventually, but in the mean time it is a fun cheap car.
Offline Covert5150
« Reply #63 on: April 30, 2014, 12:40:03 PM »
that's a funny looking kitchen.
Offline mobythevan
« Reply #64 on: May 08, 2014, 12:29:37 PM »
You should see what she cooks in there.  haha
Offline mobythevan
« Reply #65 on: October 13, 2014, 11:42:10 AM »
Quick update, this car is still running good on the rotary.  We keep driving it......
Offline XLR8
« Reply #66 on: October 13, 2014, 06:48:31 PM »
Spoon engines!
Offline Rotank
« Reply #67 on: October 13, 2014, 11:06:17 PM »
10 grand in parts, or more, if we have to overnight parts from japan.
- Tank
04 S1 RX8
91 MX5
88 C1500
Offline mobythevan
« Reply #68 on: February 09, 2015, 12:46:39 PM »
Quick update, this car is still running on what was suppose to be a bad rotary.  Hit 75k miles over the weekend.  We have put 7k miles on this $2995 priced car after only having to do the de-flooding procedure.  I am smelling some coolant, but can't locate the leak.  There is no question is will go down, but cheap fun until then.
Offline mobythevan
« Reply #69 on: June 09, 2015, 11:54:18 AM »
Wore the tires out on this car so I swapped the wheels with the other Rx8.
Offline LSXREX
« Reply #70 on: June 29, 2015, 10:04:39 PM »
So when does this turn into a build thread?
2004 LS1/T56 swapped RX8
RX8Club is for pussies
Offline Nfinitecc
« Reply #71 on: June 30, 2015, 10:03:57 AM »
After it dies, then they swap the other rx8  motor into it, then when it dies.
Offline mobythevan
« Reply #72 on: June 30, 2015, 10:46:42 AM »
Both Rx8's have dead rotaries now.  This one actually died last Friday, June 26th.  This month I am rebuilding my Rx7 drag car, see my other build thread.  My son is also swapping his Eagle Talon from automatic to 5 speed right now.  I told him to decide if we swap a V8 or Ecotec into this Rx8 over this winter.
Offline Nfinitecc
« Reply #73 on: June 30, 2015, 12:13:36 PM »
I think eco Tec would be awesome points For individuality
Offline LSXREX
« Reply #74 on: June 30, 2015, 04:16:35 PM »
Swim with the salmon and LS it. Individuals are cool but I'd rather win
