March 18, 2025, 02:40:54 AM
Author Topic: 1994 Mazda RX-7 LS2 V8 Swap LOW Miles  (Read 14366 times)
Offline Troux
« on: December 27, 2013, 12:57:24 AM »
Price: $28,000
VIN: JM1FD3337R0302632
Contact: cbonnerm(at)aol.com
1994 RX-7, R2 model
Vintage Red w/ Black interior (156 made in this year/color/trim)
18,7XX miles
2,720 lbs (1/2 tank of gas)
Chassis:
Swap done by me, including wiring (soldered)
Corner balanced
Hinson LS2 front subframe
Samberg transmission mount
Samberg rear diff mount
Full SRS (airbag) delete
Shorai Power 5lb lithium ion battery (relocated to rear bin)
R-magic Inner Fender Braces (w/ additional stiffening bar)
Engine:
2006 GTO LS2 (~21K miles)
412 WHP/398 WTQ (very conservatively tuned, but everyone says that)
Speed density tuned by Jeremy Formato (Fasterproms)
Corvette LS2 oil pan
Hinson long tube headers w/ merge collectors, ceramic coated black
Fully ported intake and throttle body
MKIV Supra Fuel Pump
Manley race valves (1mm oversize)
Cometic head gasket (.040, thinner than stock)
Comp Cams double roller timing chain with adjustable cam gear
Melling High pressure oil pump
ASP underdrive pulley
Katech tensioner pulley
Aluminum (solid) engine mounts
Custom 4" aluminum intake using Turbohoses velocity stack & K&N filter
Custom stainless exhaust using mandrel bent pipes, ceramic coated black
Burns stainless X-pipe
Dynomax bullets, dumped before axle
Edelbrock 2-piece timing chain cover (allows for easy cam swaps)
PCV system delete with K&N vented oil filler
Granatelli motorsports wrapped/shielded spark plug wires
Castrol 0W40 German Oil used
Cooling:
Spectre flexible heater and radiator hoses
Improved Racing oil cooler block w/ stock passenger side oil cooler
Howe Racing surge tank/swirl pot/ air separation tank
Modified Koyo N-Flow (triple pass) radiator, ceramic coated for heat exchange
V-mounted and fully ducted radiator (with ABS plastic)
Full AC delete
Drivetrain:
2006 GTO LS2 T56 (~21K miles)
New F-body slave cylinder
Remote bleeder
Hinson Aluminum driveshaft
Spec Stage 3+ clutch (6-puck unsprung, really not bad to drive with)
Fidanza aluminum flywheel
Delrin diff mount bushings
Pro 5.0 F-Body shifter
MGW Mustang shift handle (allows use of any shift knob)
Mobil 1 ATF transmission oil used
Suspension/Wheels:
18x10 CCW Classics, black anodized/shot peened face, lightened, with ARP hardware
295/30/18 R888's (~500 miles of use)
Ray's lightweight lugnuts
Penske 8100-based double adjustable, remote reservoir aluminum shock coilovers
Pillowball upper shock mounts
Hypercoil springs (700 lb/in F, 550 lb/in R)
Suspension Techniques front and rear adjustable sway bars
Widefoot front sway bar mounts
Improved Racing front shock tower bar w/ brake MC brace
Mazsport rear shock tower bar
Maval manual steering rack
Superpro polyurethane steering rack bushings
Kei Office brake pads
Stainless braided brake lines
Interior:
Sparco R353 steering wheel
Sparco Pro 2000 seats on Sparco side mounts
G-Force 5 point harnesses
Alpine CDA-7894 Head unit
Lower DIN map pocket (rare)
4x Infinity reference speakers (hidden as stock)
JDM leather center armrest/ashtray
Passenger airbag delete (looks stock, ~10lbs lighter)
Redline Goods Italian leather shift knob boot
MKIV Supra shift knob
Carbon fiber ECU retainer plate (hidden)
Floor mat metal scruff plate
Carbon Fiber door sills (w/ RX-7 logo)
Dash plastics in great shape: no broken tabs, replaced all plastic and metal clips and fasteners
Replaced empty center console lights with blanks for cleaner look
Exterior:
Shaved and painted engine bay
Full front harness wire delete/tuck (fuse boxes relocated to rear bin)
Powder coated many components (subframe, diff mount, ABS lines, master cylinders, engine accessories/components, valve covers, intake manifold/tube, etc.)
Painted what couldn't be coated (radiator coolant cap, wiper motor, ABS unit, brake booster, wipers, TB, etc.)
Holden Commodore VZ engine covers, painted (rare)
Smoked turn signals
EVO-R 90mm sleek headlights (HID)
'99 circular taillights
JKL Carbon fiber '99 spec front lip
Feed carbon fiber side skirts
Craftsquare carbon fiber rear add-ons/canards
APR Formula GT3 carbon fiber mirrors
VIS Scoot-style carbon fiber hood
NRG carbon fiber hood dampers
Aerocatch flush mount hood latches
Front and rear fenders rolled (not pushed out)
I have owned this car since 2007, purchased from the second owner. I did the swap at 18K miles and simply don't use it enough to keep it, so I'm willing to sell it for less than half of my investment. In the words of my tuner, the car runs outstandingly, and it's not given me any problems. My loss is your gain.
As you may guess by the seats, the spring rates, the A/C delete and the dumps, this car is not for daily driving or a plush cruise. It's got loads of grip, instant acceleration, exemplary driver feedback and a thoroughly stiff chassis, exactly as I'd planned the build for. The car was built for street and track use, but I simply haven't had enough time and interest to get in track time before now, and I don't see that changing in the near future.
Included with the sale will be all of the documentation I've kept on the car.
The bad:
The driver side headlight cover came off. I am including a new pair with the sale, so the new owner can replace one and have a backup for the other.
The front lip and passenger side rear canard have taken some bumps and have some cracks in the carbon fiber. They're each about a '10-footer.'
There are some scratches and two tiny drilled holes on the interior plastics down low, just behind the driver's seat. You really have to be looking for them.
The hood will rub a very tiny bit on the driver side engine cover. Touch it up with some red once in a while if you care.
The rain guard for the hood is a squeeze, so I wouldn't recommend driving with it. I only use it for washing.
More (larger) pictures available by e-mail.
« Last Edit: December 27, 2013, 11:58:44 AM by Troux »
Offline xbladr
Re: 1994 Mazda RX-7 LS2 V8 Swap LOW Miles
« Reply #1 on: December 27, 2013, 01:38:37 AM »
My God that engine bay is a thing of BEAUTY!
Offline WannaBeFast
  • Single and Looking
« Reply #2 on: December 27, 2013, 01:41:27 AM »
Wow hell yea... Can you wait another year till I get a job lol. Looks amazing and I never really comment on sale threads. Best of luck.
Offline UH-60Pilot
« Reply #3 on: December 27, 2013, 08:22:27 PM »
Nice Build. Should sell quick.
1997 Miata K24Z3 swapped.
1977 GMC K10 with LQ9 swap.
Offline CharmCity7
« Reply #4 on: December 28, 2013, 08:40:16 AM »
Damn, this car is sexy.  One of the cleanest I have seen.  GLWS.
-Austin
Offline cool
« Reply #5 on: December 30, 2013, 06:54:25 PM »
Love the license plate.
Clean car. Good luck with the sale.
« Reply #6 on: December 30, 2013, 08:49:36 PM »
Awesome dude! Love it
Offline Troux
« Reply #7 on: January 19, 2014, 07:24:17 PM »
Bump.
Offline gapower
« Reply #8 on: January 27, 2014, 10:26:34 PM »
One of the nicest I've seen; however, do you happen to still have the stock hood and seats?
« Reply #9 on: January 28, 2014, 02:55:08 PM »
Nicely done swap!  The rims/tires and coilovers are worth an easy $5-6K.
Offline Troux
« Reply #10 on: February 03, 2014, 12:38:37 PM »
Thank you. I don't have any of the stock parts.
I also forgot to mention that this car has the 929 brake master cylinder.
Offline usfmedstud
« Reply #11 on: February 05, 2014, 07:52:23 AM »
haha love the vanity plate! GLWS
:chug:
1994 LS1/T56, 429hp.
RLTW!
Offline Troux
« Reply #12 on: March 01, 2014, 05:11:56 PM »
Bump. Also, there are aftermarket toe links and trailing arms on this car.
Offline feedthafire
« Reply #13 on: March 04, 2014, 08:23:26 AM »
18k on chassis or swap? if on chassis this is under priced haha
1995 BB PEP (still rotary)
1994 MG PEP
Offline Troux
« Reply #14 on: March 05, 2014, 04:05:29 AM »
Chassis, see dash pic.
