I've been trying to figure out why my 93 has bump steer. It came with a samberg subframe and samberg bump steer kit with rack spacers. They were purchased several years ago so I don't know if there have been different revisions since then. It isn't severe, but it's definitely noticeable and annoying at higher speeds and rougher roads. Was thinking of getting one of those longacre measuring devices, but ended up going the cheap route this morning and zip-tied a laser pointer to a level which attached to my rotor with a magnet. Drew a line on a level sheet of paper taped to my tool cabinet 9 feet away. Over 6" of travel there was 1" of movement to the right (toe-in for driver's side). I forgot to check where resting height is on the line when the car was on the ground, but I definitely passed through it somewhere in the middle of the line. Given all that I came up with 3" of compression resulted in .12" (about 1/8") of toe-in on the driver's side tire. 3" of travel is a lot, but it's possible for one wheel to be in droop and one in compression for 1.5" of travel each resulting in
1/8" (actually, just 1/16") change in steering to either the left or right. This assumes that the passenger's side bump steer measurement comes out the same.
The next step is to try adding a washer to the bump steer kit to see if that changes the way the line is drawn. There's also the possibility my bushings are getting old (177k miles), something is bent, or my rack is going out. But other than wiggling or replacing stuff I'm not sure how to figure out which of those could be the problem. Wheel bearings and hub have less than 1000 miles. The car was raised up 0.25" last weekend, but the problem is still there. Seeing how straight the line is I can understand why nothing changed. I attached a pic of my bump steer kit in case it's installed incorrectly or I'm missing a part. The largest diameter part is about .8" tall. The rack spacers are .75" thick.
Any ideas?
