Updates!
I feel like I should make a "new member introduction". As its been near about 2 years since I've posted. Some things have happened. Traveled to Brazil. Started dating long distance, got engaged to a Foreign Nat. Moved into a new house, (2 car garage! barely...its a squeeze). Picked up another car, Manual IS300. She's fun. I have some things getting ready for this car. Namely some Fortune Auto Coils, bushing updates, caster arms.
Got married to prior mentioned foreign national. Now the process to get her immigrated proper to the US. We did a civil ceremony to get the paperwork started, we are going to have our ceremony 1 year out from now. 09/2018
The swapped 7 moved with me to the new house. I trailered it to friends shop to finally get the exhaust work done. It sounds great. A bit louder than I had intended, and louder than either of us expected given 2.5 inch pipes to a 3.5 inch center section running back to 2 'magnaflow' copy mufflers and small 'stock-ish' turn-downs. He took care of some electrical gremlins, found the battery wasn't charging because alternator was dead. There are a few small things to fix. I need to put my 'turn signal switch' in a reach-able place. The Tach doesn't read right, needs a 10k Pull up resistor. The Gas gauge reads in reverse sweep (whoops). I'll get some interior pictures going. I want to swap out my tired steering wheel. I want to use a sprint car aluminum wheel with a quick release, looks like I might need to do a weld on spline.
Drove it some, breaks traction stupid easy. Has some rear 'juddering' which I think is likely the axles/CVs. I think the ronin 8.8 is in the future. First needs to get aligned. Need to swap passenger motor for crank windown, and attach door card with handle, make it a bit less clapped out. Oh and the battery box. Thats a thing I need to finish.
Extras
Cars separated by 50 years. Too bad his isn't a fastback, would have been perfect!
Daily at night with winter wheels and tires
