Haha thanks for the encouragement!
A few updates in words. a few pictures. And a promise for more pictures because I should.
For starters, I got the engine lifted back up into place and everything cozy where it belongs. I also got a very exciting box shipment in from California
PBM Angle Kit. It is currently fully installed, no pictures of the install process, but it wasn't so bad. While I was fussing with the hubs I put in extended studs. I used the JEGS ones that people here have posted as fitting.
Also since I knew it would be a new sort of "catch" point, or really just in the way, I decided to move the brake lines. They are now on the "back side" of the shock tower and closer to the tower itself. I just opened up one of the holes already in the fender well. I used AFCO Kevlar brakes instead of stainless braid. A-because they won't rub through things and I don't have to worry about them getting dirt into the braid, and B because I like them being a bit more discrete than flashing silver lines everywhere. Because I was shortening the lines I went ahead and did the line across the engine bay as well. I'll grab some pictures, looks great IMO, had some slight difficulty with the banjo bolts I was using. I installed a brake pressure switch since my factory wiring is missing, should be easy to power this one.
After tracing down some leaks I managed to get the brakes bled (got new speed bleeders too, was fun putting the rears in without taking the wheels off). So, clutch is done, Brakes are done, Power steering is filled and cooler located.
On to the last "hold up" of the whole thing. The radiator. I decided I really liked Akina's build. So I called up Howe Racing and I eventually sent them the dimensions I'm looking for and the fan model. They need to get back to me on an estimate but I know I will be happy going this route. Going for a double pass with both inlet/outlet on the right side. Fans will fit. no filler. Anyway here's the mock up!
I realize that in the fan picture there's no accounting for the endtank. Assuming the end tanks are a minimum of 1.5 inches there will be a very VERY small amount of overlap on the driver-side fan where it is on the end-tank. I'm happy with it.
Might have to get a bit creative with hoses, and one day I'll need to get a sick mandrel bent pipe like Akina's down the center. Then I'll start dreaming up how I want to do the extraction hood!
