March 17, 2025, 02:33:48 AM
Author Topic: complete FD turbo kit $3500  (Read 4468 times)
Offline gaspo
« on: September 23, 2013, 11:14:50 PM »
i got this turbo kit from a member on here Kev2769. its got a borg warner turbo from bullseye S372 with an s400 frame, dual tial wastegates, tial blow off valve, truck manifolds, 60lb injectors, down pipe, custom radiator, intercooler and all piping, 2bar MAP, oil feed and drain lines.  i'm in the process of installing the kit, but if someone want it i'll sell it.  i have the hinson motor mount kit and he had the samberg.  this kit was built for a samberg mount kit.  the downpipe needs to be changed if going into a car with the hinson swap kit.
 text or call for pictures.  616-510-0793.
the turbo kit made 587rwhp and 599ft/lbs at 11.5 lbs of boost on a stock ls1 with 317's.
« Last Edit: September 23, 2013, 11:41:04 PM by gaspo »
Offline Spec C
Re: complete FD turbo kit $3500
« Reply #1 on: September 23, 2013, 11:26:48 PM »
Pictures of kit?
Offline gaspo
« Reply #2 on: September 23, 2013, 11:31:44 PM »
i'm trying to load up the one that i have of the hotside installed on my car.  also asked kevin to send me some he might have.
Offline kev2769
« Reply #3 on: September 24, 2013, 10:12:10 AM »
I will do my best to get some pics up tonight for you.
Offline gaspo
« Reply #4 on: September 24, 2013, 10:14:18 AM »
thanks kevin!
Offline gaspo
« Reply #5 on: September 25, 2013, 05:18:28 PM »
bump!
Offline kev2769
« Reply #6 on: September 26, 2013, 12:40:01 AM »
couple pics
Offline kev2769
« Reply #7 on: September 26, 2013, 12:40:54 AM »
more
Offline kev2769
« Reply #8 on: September 26, 2013, 12:42:07 AM »
then there was more
Offline kev2769
« Reply #9 on: September 26, 2013, 12:43:08 AM »
Time slips
Offline kev2769
« Reply #10 on: September 26, 2013, 12:48:43 AM »
Video of the 10.59 pass with 1.49 60ft
This was my first pass with the turbo setup.
Offline kunz111
« Reply #11 on: September 27, 2013, 08:10:38 AM »
So I take it you can't use an air filter on this set up, looks like the turbo inlet is to close to the radiator. Is that right or am I just seeing stuff?
Offline kev2769
« Reply #12 on: September 27, 2013, 09:33:21 AM »
You can put a screen but not a filter unless you modify a radiator setup to give more room.
The whole idea was to not get hot air from the engine bay but of course it leaves the turbo open for other possibilities.
Offline gaspo
« Reply #13 on: September 27, 2013, 11:52:47 AM »
The plan is to use a screen. Where the turbo sits and how the inlet is I wouldn't be worried about it at all.
Offline gaspo
« Reply #14 on: October 10, 2013, 03:55:52 AM »
bump
