i got this turbo kit from a member on here Kev2769. its got a borg warner turbo from bullseye S372 with an s400 frame, dual tial wastegates, tial blow off valve, truck manifolds, 60lb injectors, down pipe, custom radiator, intercooler and all piping, 2bar MAP, oil feed and drain lines. i'm in the process of installing the kit, but if someone want it i'll sell it. i have the hinson motor mount kit and he had the samberg. this kit was built for a samberg mount kit. the downpipe needs to be changed if going into a car with the hinson swap kit.
text or call for pictures. 616-510-0793.
the turbo kit made 587rwhp and 599ft/lbs at 11.5 lbs of boost on a stock ls1 with 317's.
