It's an extension of the CMP. Dunno why they extended the mofo all the way up there, but it uses a different pinout and different connector than the one behind the intake mani. If you pull it out (from the male side, at the 33/34 location) all the way to the CMP location, you can remove it, and relocate the wires that connect to the female connector to the rear of the intake mani. You must repin it to the CKP connector at position 28. Swap it color for color. This little jumper harness is only on 98-00 F body harnesses.
Make sence?
