March 18, 2025, 04:37:09 AM
Author Topic: 93 Ls3 Rx7 8.8 Cobra IRS T56 - lots of mods - norcal  (Read 10226 times)
Offline ipeefreely
« on: August 02, 2013, 05:28:38 AM »
So I've been thinking about selling my car mainly because I feel like I'm starting to hit the end point of the build now and thus I'm losing interest in it.
Don't get me wrong. It's not that it isn't a great car but I'd like to move onto other projects.
Anyways, without further ado.
I bought the car off dark-one last year around April.
His for sale thread was here: http://www.norotors.com/index.php?topic=7412.0
When I bought the car last year, it came with a turbo'ed Ls6.
Despite dark-one's "guarantee", anything and everything that went wrong with the car, did. Bottom line was that the car was NOT how he described it to be at all.
You can see my build thread for a longer explanation here: http://www.norotors.com/index.php?topic=11637.0
Long story short, I ended up almost replacing everything with brand new parts. It was a HUGE and lengthy ordeal for me but when it was all said and done, was actually quite satisfying. That and it provided an opportunity to work out all the kinks.
The mods on the car are as follows:
Interior:
Floor mats
Sakebomb Garage passenger door handle
Tillet B1 Seats   2,500 per seat
Combination Switch   169
Driver Side Carbon Fiber Door Panel
Passenger Side CF Door Panel
Seibon Carbon Fiber Door panels
NRG - Quick Release Hub
SRK-250BK - Quick Release Gen 2.5
Momo Nero Shifter Knob
MOMO Jet Steering wheel - 320mm
Driver side + Pass Side Window Motors
Inner A Pillars
Consol / Trans Cover
New Center Console
Combo Switch
Rear Interior Panels
Brand New FI LS1 / LS6 Engine Harness
ALL NEW Interior Screws, Nuts, and Fasteners
Sparco Aluminum Seat Rails
Sparco 4-Point Seat Harness (Black)
Eclipse Satellite touch screen Navigation
Drivetrain and Suspension:
IMPROVED RACING front tower strut brace
ENDLESS MX72 Front Brake Pads
AP Brakes
Fixed Rear Axle
Autoexe  Tower Brace Set FD3S 13B
Brand New Differential
Titek Lug Nuts
Axle Clamp
Greddy Coilovers
Front sway bar reinforcement bar
Engine & Exhaust:
Harness Extension + Pulley
OBX 4 " Exhaust Clamp V-band with .5" Rail
Built Ls3 - Forged
Specs for built Ls3 are here: http://ls1tech.com/forums/parts-classifieds/1566270-fully-built-ls3-boost-extras-stage-v-flt-4l65e-zero-miles.html
Granny's speedshop mounts
Throttle Body
Samberg Radiator Kit V2 -
Samberg Bump steer kit (with rack spacers)
New 2001 Camaro Oil pan w/ Gasket
Improved racing high performance sway bar links - Fronts
Improved racing high performance sway bar links - Rear
2001 Camaro water pump
Valvoline - Automatic Transmission Fluid: ATF+4
Valvoline - Motor Oil: RACE20-50
Red Line® Synthetic Oil WaterWetter® - Super Coolant: 80204
2008 Corvette Timing cover w/ cam sensor - Ebay
JTR Headers Ceramic coated
NGk TR55 Spark Plugs
LS3 Injector Lower O-rings
LS3 Dipstick
K&N Oil Filter
LS1 160 Thermostat
Coil Pack
J Magic Full Ti Exhaust
Tune / Remap
Breather / Catch Can system
Exterior / Lighting:
JKL Racing Rx-7 Carbon Fiber GTC Bumper w/ Diffuser
Feed Engineering Lights HID
Mazdaspeed GTC lens covers
SBG Hid Projector Headlights
Fno1-c 5zigen wheels 9 inch wide fronts, 10 inch wide rears
Other / Misc:
Sumped gas tank
weldon 1000hp pump -10 feed lines
Siemens deka #80's
Aeromotive fuel rails and press reg
T56 with McLeod twin disc
Polluter cam
Crane heavy duty push rods and double valve springs
Al power steering pump pulley
Greddy turbo timer
8.8 Cobra IRS
Power Steering
The Bad:
- The exterior could use some loving. Paint is fading after 20 years. Also, front driver side fender needs some repair work done to it (car bottomed out before).
- No A/C - I have all the parts for it but no idea how to run the lines.
- Radio doesn't work. Not that you can hear anything anyways cause the car is so loud.
The car is fully dialed in to be capable both on the street and the track. I've put about a 1000 miles (all street cause I have never even been to the track) on the build since it was completed 3 months ago.
The car was recently tuned by Rick @ Synergy Motorsports in fremont and made about 412 - 430 hp. The engine is fully built though and is capable of handling turbo or a much more aggressive cam set up if you desire.
Title is clean and in hand. Registration was done back in March, 2013 so it's still pretty fresh.
I'm asking 28k obo or 25k without the seats.
And more (interior) photos:
Videos:
Feel free to pm me or call me at 510-282-5651 if you have any questions.   Thanks
« Last Edit: August 28, 2013, 03:04:10 AM by ipeefreely »
Offline hamm0
Re: 93 Ls3 Rx7 8.8 Cobra IRS T56 - lots of mods - norcal
« Reply #1 on: August 04, 2013, 11:44:48 PM »
Whats wrong with the drivers door/fender?  Any better pics of that?
Do you have any other interior pics?
Also, does the car come with the parts that were on the car when you bought it from darkone?  I'm thinking of the cage + Alcon calipers.
Thx.
Offline usmcpi
« Reply #2 on: August 11, 2013, 08:53:03 PM »
you paid $313 for floor mats?
Offline Ebush
« Reply #3 on: August 11, 2013, 09:02:22 PM »
J Magic (I think) Full Ti Exhaust - 2200
You paid $2200 for exhaust, and your not positive what it is?
Offline chuckdog_5
« Reply #4 on: August 11, 2013, 09:26:23 PM »
This is off to a good start...
Offline ccdominic
« Reply #5 on: August 11, 2013, 10:13:54 PM »
I wanna play!  Aren't the sake bomb handles 220 new on their site?
Offline usmcpi
« Reply #6 on: August 11, 2013, 11:35:01 PM »
These are £1,073.00, which converts to $1662, from Tillet direct (https://www.tillett.co.uk/shop/shopdisplayproducts.asp?id=29&cat=B1+Racing+Car+Seat).  I'm sure some vendors even carry them cheaper.  Besides, wtf was wrong with the Sparco's that were in it?
Fixed Rear Axle   40.00
Valvoline - Automatic Transmission Fluid: ATF+4   56
Valvoline - Motor Oil: RACE20-50   18
Red Line® Synthetic Oil WaterWetter® - Super Coolant: 80204   11
NGk TR55 Spark Plugs    29.15
LS3 Injector Lower O-rings   10.88
LS3 Dipstick   18
K&N Oil Filter   17.82
LS1 160 Thermostat    20
Seriously?
Built Ls3 - Forged   7500
Funny, because that sale thread says $6500
Tune / Remap - 900
You paid $900 for a NA tune?  It came with a turbo, you bought a forged low compression engine, and now its NA....?  And you call that the end of your build?
« Last Edit: August 11, 2013, 11:43:50 PM by usmcpi »
Offline ncaudio
« Reply #7 on: August 14, 2013, 10:37:17 PM »
Off and running :popcorn:
'88 FC LS T56, 94 FD LS T56, '93 FD was LS turbo T56 Ford 8.8 IRS Ablake's old car (project)
Offline 1point3liter
« Reply #8 on: August 14, 2013, 10:56:25 PM »
in on page 1
-Bryan
Twin Turbo LSX FD
Offline TS motorsport
« Reply #9 on: August 18, 2013, 12:20:09 AM »
You guys are so harsh haha. Those seats look super uncomfortable btw.   :scratch:
04' Nighthawk Black Acura TSX 6spd/ 08' Prius 5/04' Maxima 5spd
Offline cool
« Reply #10 on: August 18, 2013, 11:11:28 AM »
I'm glad I wasn't the only guy looking at this and thinking WTF. I just bought a car for the price of those seats, exhaust, and tune.
Offline Elixirvtec
« Reply #11 on: August 19, 2013, 06:07:47 PM »
popcorn......
Offline ipeefreely
« Reply #12 on: August 21, 2013, 11:57:04 AM »
Woops. I probably shouldn't have just copy and pasted everything from my excel sheet without looking it over. Sorry for all the errors guys =P
I've edited out the prices on my original post since you guys seem to be picking at the prices of my parts rather than evaluating the car as a whole.
Price of the car is still at 32k obo with everything or 29k obo without the seats (since it seems like some of you dislike the seat set up I currently have in there anyways).
For those of you who have anything to say to me regarding things that don't necessarily contribute to the sale, I welcome you guys to private message me.
« Last Edit: August 21, 2013, 02:28:36 PM by ipeefreely »
Offline ipeefreely
« Reply #13 on: August 21, 2013, 12:05:04 PM »
Thx.
Cage is gone. Alcon calipers were sold / traded awhile back on the build. AP racing brake set up was installed in place.
I'll get some more interior pictures of the car when I can. Car is parked in my parent's garage.
Offline ChriS2000
« Reply #14 on: August 22, 2013, 07:08:40 PM »
 :popcorn:
I like the seats.
