March 16, 2025, 04:26:55 PM
Author Topic: 4.3L V6 / TH350 -> 85 FB  (Read 6397 times)
Offline Aatxe
Re: Backyard 4.3L -> 85 FB swap
« Reply #15 on: August 24, 2013, 10:37:12 AM »
19" tall 22" wide. Think it was very similar / exact same size as the stock radiator
Offline SSjon
« Reply #16 on: August 24, 2013, 10:46:41 PM »
That radiator fits nicely. What size is it?
Too bad there is now no room for a sway bar, or radiator fan if it was a V8
L33 T56 8.8
Offline Aatxe
« Reply #17 on: August 25, 2013, 03:07:51 PM »
  We couldve mounted farther up front and left the sway bar in, but we chose to take it out as we are sticking to more of a drag car type theme.
Offline Aatxe
Re: 4.3L V6 / TH350 -> 85 FB
« Reply #18 on: September 01, 2013, 08:42:20 PM »
Finally got some spare time and got the engine compartment cleaned / painted. Will be dropping motor in tommorrow....looks WAY nicer in person....pic doesnt do it justice :D
Offline Aatxe
« Reply #19 on: September 02, 2013, 06:42:21 PM »
Tons more work to do but engine = in :D
Offline N2v8fcs
« Reply #20 on: September 02, 2013, 09:49:37 PM »
nice clean install
keep up the good work.
:drive:
Offline Aatxe
« Reply #21 on: September 03, 2013, 01:32:34 PM »
nice clean install
Thanks!  :D
Now to clean up the harness and figure out a few minor problems....then can move on to the rear end. So much to do!
Offline Aatxe
« Reply #22 on: September 28, 2013, 10:12:25 PM »
Been awhile! Been busy fixing little things....getting the tranny all set up and trimming down the electrical system. Finally had it start yesterday though! Only have a Y pipe on it and still have some stuff to clean up / do better but very satisfied :D
Technically the second start up....had a video of the first but we didnt have the torque converter bolted up and the air from the flywheel spinning actually started spinning the converter anyways....caught it quick though. Runs great so far though, the video I posted was before any messing with timing at all...was very satisfied with how everything turned out.
