Found a great deal on this so it needed to be done.
I'm really tempted to gather the other components (tank,pressure lines,block feed fitting,filter adapter,cooler and possibly a vac limiting valve) and install it on my factory bottom end. It should improve ring seal and provide a greater sump capacity at the least.
Something else I'm considering when I go dry sump is to run a mechanical fuel pump off of the rear of the pump. Its the ultimate in simplicity and could make for both a higher flowing and more reliable pump arrangement than I currently have.
The only question is if a surge tank is necessary on a mechanical fuel pump setup if I were to run a check valve inline near to the tank (sumped fuel cell) and the feed line is of appreciable diameter (-10).
Thoughts?
