March 20, 2025, 09:53:35 PM
Author Topic: 2jz FC3S  (Read 31772 times)
Offline Cam_Ron
2jz FC3S
« on: July 12, 2013, 06:20:58 PM »
*This build thread is to help keep me motivated and for some input as the car starts to come together*
   In my opinion, RX-7's are great cars, and I really like the rotary engines that they come with but I just can't justify the expense of a reliable 500+whp 13b. With that said I've been putting jz's into FC's since 2009 and have had alot of fun doing so. Here is my current project:
Goals:
-500+whp on pump gas, 700+whp on pump + meth
- 10 second quarter mile of some sort
- 3000lb with me in it and all fluids
- capable on the road course
- street legal
Mods to date:
Engine/Trans:
2jz-gte/v160
- gsc s2 cams
- gsc behive springs
- gsc Ti retainers
- gsc viton valve seals
- RMR 90mm throttle body
- Sheetmetal intake manifold
- custom ss exhaust manifold
- -8AN valve covers
- D585 ignition coil conversion
- TiAl mvr44 wg
- Greddy Type R bov
- Mishimoto 24x12x4" intercooler
- koyo rad with AN inlet and outlet
- Megasquirt ms3x
- Greddy T88-34d (billet wheel ready to go in some day)
- - 8 fuel rail
- 1680cc injectors
- dual bosch 044 pumps (-6 line each to y before rail)
- Al fuel cell
- Integrated engineering surge tank
Body/Interior
- All rust cut out and repaired
- cage
- Underside and wheel wells are POR 15'd
- Interior and engine bay are painted white
- Ronin widebody fenders and quarters
- shine fc2000 rep front bumper
- Sparco pro2000 seat
- Cobra Evolution seat
- Stack st8130p
- OMP wheel and quick release
Suspension/Brakes/Wheels
- Front and rear subframes, knuckles etc sandblasted and POR 15'd
- New calipers and porterfield r4 pads
- supernow fd rear rotor conversion
- supernow outer tie rod ends
- Delrin bushings (subframe, control arms, trailing arms, diff)
- ST sway bars with spherical end links
- Panasport c5c2's with custom lips 11x17 front ,  275/40/17 Sumitomo HTRZ II (chunky I know) and 11.5x17 rear with 315/35/17 Nitto NT555R's)
I still need to get many things before this is complete but some of the first items will be:
- coilovers
- aem tru boost
- aem failsafe wideband
- wire/relays etc for chassis and starting/charging harness from scratch
- more nozzles for the meth kit (thinking about one in each runner)
- paint for hood, doors, fenders, bumpers, quarters, and the rest of the car
- driveshaft
- brake lines
Here are some pictures:
(Taken by RB)
This is where the car is as of this evening:
Offline Cam_Ron
Re: 2jz FC3S
« Reply #1 on: July 12, 2013, 06:24:02 PM »
Currently working on my transmission mount and trying to figure out how I'm going to plug all of the holes in the floor and firewall in a sanitary way. Any ideas on what I should do for plugs?
« Last Edit: July 12, 2013, 06:43:35 PM by Cam_Ron »
Offline Sho Amo
Re: 2jz FC3S
« Reply #2 on: July 12, 2013, 09:53:32 PM »
Get an assorted grommet kit. Or post a wtb on rx7 club for anyone with a parts car.
[Sold] '90 GTU LS1/t56
Offline Cam_Ron
Re: 2jz FC3S
« Reply #3 on: July 12, 2013, 11:56:58 PM »
A set of grommets like this http://www.easternbeaver.com/Main/Elec__Products/Grommets/grommets.html would work for the firewall and I suppose I could use push plugs (like the ones that hold in oem wheel well plastic) for all of the little holes created when you remove the interior and sound deadening. Any feedback from those with stripped interiors?
Offline FC3S Murray
Re: 2jz FC3S
« Reply #4 on: July 15, 2013, 12:16:00 AM »
Nice work on making it essentially a "clean sheet of paper" to start with. Can't wait to see the progress.
SRM Performance Tuning LLC
Offline Mtalon
Re: 2jz FC3S
« Reply #5 on: July 15, 2013, 01:49:37 PM »
 :popcorn:
Offline Cam_Ron
Re: 2jz FC3S
« Reply #6 on: July 15, 2013, 10:01:51 PM »
Thanks guys. Not much progress to report other than revised the brackets that secure the fuel rail to the intake manifold and ordering some parts from the Mazda dealer to rebuild the diff (Has anybody done this?).
Offline screamin88
Re: 2jz FC3S
« Reply #7 on: July 16, 2013, 10:12:29 AM »
Awesome! I'll be watching this for sure!
Offline N2v8fcs
Re: 2jz FC3S
« Reply #8 on: July 20, 2013, 02:23:48 PM »
Are you going to piant the exterior back red ?
:drive:
Offline Cam_Ron
Re: 2jz FC3S
« Reply #9 on: July 21, 2013, 11:07:31 AM »
The plan is to paint the exterior the same colour as the interior and engine bay. It's called GM Olympic white.
Offline Cam_Ron
Re: 2jz FC3S
« Reply #10 on: July 21, 2013, 11:28:12 PM »
Put the intake manifold and exhaust manifold + turbo on.
The exhaust manifold needs to be modified some more so the turbine housing will clear the strut tower and I need to decide on the final position of the wastegate.
As for the intake manifold, the mounting tabs that secure the fuel rail were interfering with the cps sensors (not required with my ems so I'll make blanks at some point). A little cutting and welding solved that problem though. I even got a free TIG lesson out of it.
Offline Sho Amo
Re: 2jz FC3S
« Reply #11 on: July 22, 2013, 05:39:09 PM »
Looking great!
Offline youdontknow
Re: 2jz FC3S
« Reply #12 on: July 22, 2013, 08:24:17 PM »
Nice! Why don't go E85?
Offline Cam_Ron
Re: 2jz FC3S
« Reply #13 on: July 22, 2013, 08:28:24 PM »
Thanks. E85 isn't available. The highest ethanol content I can get is 10%. I'm hoping that with a proper meth setup I can get close to the same power as an e85 setup would make.
Offline AKINA FC
Re: 2jz FC3S
« Reply #14 on: July 22, 2013, 10:30:19 PM »
Looks great! Looking forward to watching this come together! :cheers:
