March 18, 2025, 05:54:13 AM
Author Topic: FD Explorer 8.8 Diff Kit  (Read 235408 times)
Re: Announcing FD Explorer 8.8 Diff Kit
« Reply #150 on: October 23, 2013, 02:17:42 PM »
No recommendations per say.  However, to and from shipping may cost you about as much as the rebuild so I'd tend to suggest you look locally. I've had good success on a variety of referrals by calling my local speed or 4x4 shops and checking who they use.  Bowtie7 found his local Ford dealership serviced a variety of go-fast mustangs and had the resident expert at the dealer to do his.
Effectively, any shop that will ask you what you intend to use the diff for in picking a backlash number is the kind of place you want to be.  Heck try yelp and search locally for differential or transmission shops then give folks a call and vette them out.  If they don't know what a case spreader is then you walk away fast.
« Reply #151 on: November 18, 2013, 03:23:32 PM »
FYI: all the hard parts are in our possession.  I'm just waiting on CV boots and then the first full batch of kits will be ready to go out.  I just sent an email to all the pre-orders / testers.  We did make a few extra kits in this first batch so we're going to have them available to others.  Price point will be $1199 plus shipping (estimated at ~$60 but we'll know for certain once we've packed the first few).
Like our FC diff kits, because this now involves welding we're planning to ship these bare w/o powder coat.  If you really want it all done at the same time we can powder but we'd leave about the last two inches of each welded interface bare.  As usual, shoot us a line at roninspeedworks@gmail.com if you have special requests.
We're also going to be offering this with the Ronin-ized Samberg engine mounting as an upgrade option and an alternate means of doing away with the power plant frame.  That gets you our engine interface pedestals, powdercoat for the engine mounting gear, your engine /trans isolators, AND halfshafts / rear end solution, all in one place.
« Reply #152 on: November 21, 2013, 09:13:58 AM »
I'd be interested in the complete list of all that's included in the rear kit. Unless I missed it.
I honestly didn't think you'd have it ready so soon. I'll be ordering one for sure just a matter of when. The 4.10 gears have to got to go.
Is it the frame, halfs and boots?
Offline MoparX
« Reply #153 on: November 21, 2013, 12:24:11 PM »
Nevermind, please delete.
« Reply #154 on: December 04, 2013, 03:37:18 AM »
Sorry I missed this:  Kits are now shipping with the following:
•   Front Mount Support Bridge (weld in)
•   Rear Mount Diff Ring Cradle (bolt on)
•   2X Custom 4340 heat treated axle bars (Ford to Mazda conversion)
•   2X EMPI CV boot kit 86-2127 (outer CV joints)
•   2X EMPI CV boot kit 86-2103 (inner CV joints)
•   Hardware
o   10x  5/16-18 bolts w/ washers support the Rear cradle
o   2x  M12x1.75 bolt w/ washers and metal lock nuts are the primary front mount hardware
o   2x 3” Heavy fender washer (supports below front mount)
o   6 reinforced rubber washers (front mount isolation, 3 per side)
•   RTV silicon (for rear cover installation sealing
•   Instructions and spec
« Reply #155 on: December 04, 2013, 04:27:20 AM »
Thanks for the update.
So the needed list is:
Driveshaft (DSS I'd imagine)
Diff and housing
Inner stubs/tri bearing thing (brain fart on the name)
Paint/powdercoat
Welder
Sounds pretty damn good to me!
Hopefully this isn't a limited run kinda thing. I'm going to be ordering this when the funds are available.  :secret:
« Reply #156 on: December 04, 2013, 12:18:53 PM »
Only things you missed are rear mount bushings and FD outer CVs.
We're planning on keeping these in stock for quick delivery to folks.
Offline dregg100
« Reply #157 on: December 05, 2013, 07:53:58 PM »
Got mine today, everything looks great.  If I could offer something up right off the bat, you need stronger bags for the bolts.  All of them broke so I had to dig through all the peanuts to find all the washers and bolts
« Reply #158 on: December 06, 2013, 11:51:47 AM »
Sorry about that.  I kinda raided the kitchen to get these out the door.    :secret:   We'll get some proper parts zip locks ordered.  Been meaning to do that.
Offline UH-60Pilot
« Reply #159 on: December 16, 2013, 11:40:15 AM »
Question, do the ford mounting tabs on the cover need to be cut off? Or is there a cover that does not have those tabs?
I found an 07' Mountaineer differential with 22K mile 3:55 ratio locally for 350 bucks. Seemed like a good deal.
My car currently has a rear Sub-frame that has been modified by Paul3rd gen. It eliminates the torgue arm. The setup looks very similar to what you guys have made for the 8.8. I have a 3:90's now w/KAAZ. I'm looking to sell this setup and install the 8.8 for better gearing options.
I will be placing an order next month.
1997 Miata K24Z3 swapped.
1977 GMC K10 with LQ9 swap.
Offline quinns
« Reply #160 on: January 09, 2014, 03:35:11 PM »
Yes the ford mounting ears on the cover need to be cut off.
I ordered the cardone complete cv axles. part # 66-2193 and 66-2194. The tripod bearing inside them appears to be smaller and WILL NOT WORK. I'm going to head to the local ford dealer and order some and see what's up.
So far impressed with the kit. The bushings are definitely a TIGHT fit. I used delrin ones that were installed in my car by previous owner. They were peeling slightly when I pressed them in.
1997.5 Hummer H1
2006 Hummer H2 SUT
Offline Ls2Rx7
« Reply #161 on: January 10, 2014, 01:09:24 AM »
I need this on my supercharge rx7!! Tire of breaking diffs!!
Ls2, Tick Sns 2 cam, A&a c6 kit, LS3 top end, 760/640 @ 13.5 psi
Offline Ls2Rx7
« Reply #162 on: January 10, 2014, 01:35:26 AM »
So would I need to get a diff first and then tack the bars on!? I have a tig welder so I can do this and this kit is something I had in my head but just never really went to deep into it. So the kit you sell is parts only and I need the diff and stuff!? Sorry if I've missed your reply on this. Too many pages to read but I love the way it looks. Also I can ship and bare subframe if you so wanted to weld it for :) also there's Over 10+ explorers at our local junk yard too..
Offline quinns
« Reply #163 on: January 13, 2014, 05:10:31 PM »
Got mine welded in.
Back from the sand blaster finally.
« Last Edit: January 18, 2014, 09:43:08 PM by quinns »
1997.5 Hummer H1
2006 Hummer H2 SUT
« Reply #164 on: January 17, 2014, 12:24:03 PM »
<------is jelly
