Has anyone tested this yet? The 4.10s are starting to get to me and was hoping this would be sorted out soon so I can get a 8.8 with more reasonable ratios in there.
I've got mine in, just finishing up the build of the diff itself (bought a new housing and it's been an experience). Mount fits wonderfully, axles went together easily, very pleased.
The problem I have stems from the fact that the new diffs (everything made in the last couple years) have these incredibly large bearings right behind the pinion gear - an extra 1/2"+ bigger than the "old" 8.8 pinion bearings... this means that if you buy a new diff - even if it's a replacement for a 2006+ 8.8 - it'll need the new bearing.
That bearing is a dealer-only part, and costs $110+.
We missed an event this weekend because I couldn't get that bearing until Friday afternoon, and we're having the damnedest time shimming this thing. With the power that we're making, the gear pattern has to be pretty spot-on, and whenever we get a pattern that's close (meaning tips of the edges) and shim to get it better, it seizes. It's going to Performance Gearing tomorrow to get handled.
As far as the swap kit, it's wonderful. The bars are close to the chassis, but with a minute of work, I was able to get my 10an/8an fuel lines in between with some hose to damp vibrations
We made these delrin bushings for the front, they're a light press fit and include the 60* taper as well as the chamfer at the bottom. Pinion angle will be set and future sets will be lathed with the correct spacing up top. I thought I took pics but I guess I'll have to find them - I'm sure my machinist or myself will sell them if people need them.
