Pictars:
Engine/tranny in after some custom mods to the Ronin tranny mount to fit the 2004r and keep the engine off the firewall:
Mac mid, tranny dip stick, Tein camber plate:
Dropped on the Tein coils:
What you can't see in the pictures is the new lower control arms with poly bushings, new hubs w/ fresh bearings and extended lugs and new brake rotors. Calipers need torn down, cleaned up, fresh pads and new brake lines, so those are off the car for now. I have one of the swaybar endlinks redone with poly bushings also, I'll put those back in when I do the brakes. Going to try and get the rear hubs swapped to ones with DTSS bushings/extended studs/fresh bearings as well as the Tein's out back tomorrow night.
Coming along nicely though. Next up after that will be swapping the crank pulley, dropping on accessories, and pulling the dash for wiring. Then it will be fuel system, cooling system, driveshaft, exhaust, test drive.
