March 16, 2025, 01:26:10 AM
Author Topic: NXTFab first shop build! FC lq9 / th400  (Read 12509 times)
Offline NXTFab
Re: NXTFab first shop build! FC lq9 / th400
« Reply #30 on: August 20, 2013, 11:02:09 PM »
the mounts are not done yet, there only tacked in place. We still need to box them in, make some support gussets and weld on doublers for the bolt holes.
nextlevelfabrication.com
« Reply #31 on: August 20, 2013, 11:03:52 PM »
Progress looks good.  :)
Offline NXTFab
« Reply #32 on: August 20, 2013, 11:16:34 PM »
hey random question for you digital. how much clearance is there form your crossmember you made for the upper mounts and the driveshaft? i cant see it being able to fully move up and down without hitting ours but we figured that when we first started. were thinking of cutting out the center once its upthere then building a driveshaft loop right where we cut to still connect everything.
« Reply #33 on: August 20, 2013, 11:21:23 PM »
My mounts angle down from the crossmember.   I don't know the clearance off hand, beyond "bunch".
Offline NXTFab
« Reply #34 on: August 20, 2013, 11:53:25 PM »
Ya our top hole put the upper arm parallel to the ground at 0 pinion angle. But just seems like it will prob need a litt more clearance in the cente. We will findout soon hahahha
Offline NXTFab
« Reply #35 on: August 21, 2013, 12:35:22 PM »
5/8 lug nuts showed up. There stupid big. And very expensive hahahha even with my discount after shipping there $6-7 a pop
Offline NXTFab
« Reply #36 on: August 21, 2013, 02:14:52 PM »
Coilover mounts showed up too. Everything rear end and fuel related is all in and ready to be installed. Ball should get rolling realybquick from here!
Offline NXTFab
« Reply #37 on: August 22, 2013, 01:36:56 PM »
Offline NXTFab
« Reply #38 on: August 22, 2013, 01:38:36 PM »
Offline N2v8fcs
« Reply #39 on: August 22, 2013, 05:14:14 PM »
nice wheel & tire package
:drive:
Offline NXTFab
« Reply #40 on: August 23, 2013, 08:42:05 AM »
295/55/15
Offline trickygotmein
« Reply #41 on: September 22, 2013, 01:21:08 PM »
I dig the wheels and tires ! I wish I could run more than 275's. Keep up the great work.  ;)
:D     W A R   H O R S E      :D
