Hey guys, been on here for a wile and you guys have been awesome. Starting a fabrication company with a good buddy of mine. Nothing huge but something to get all us DI"Y" guys by without having to break the bank. and i say DI"Y" because one of the things we will offer is SHIP TO WELD. witch means you send us a pipe or item you want welded, mark the item up all you want with what you want cut and welded or a flange and location and we ship you back a complete assembly! Quick run down of our project car
87 Fc rx7 (gxl model i believe):
05 lq9 - stock block
l92 heads - stock ports
ls3 intake and injectors - stock
brian tooley valvesprings retainers
custom TIC performance cam
rossler T2 th400
PTC 10" converter
295/55/15 mickey thompson drag radials
... and more!!
RUNNING LOG OF WEIGHT REDUCTION STUFF:
Fuel tank, straps, brackets, fuel fill neck, and other associated misc tubing: 40lbs
Carpet, foam under carpet, 80% sound deadening: 50lbs (+ / - 5lbs there was random wires in the bag also)
