March 29, 2025, 04:48:54 PM
Author Topic: 1994 RHD R2 Project: 2JZGTE/TH400  (Read 44145 times)
Offline Demon
Re: 1994 RHD R2 Project: 2JZGTE/TH400
« Reply #75 on: October 21, 2012, 09:00:42 PM »
ID1000's, why such small injectors? What fuel are you going to run?
Offline mefarri
« Reply #76 on: October 21, 2012, 09:06:42 PM »
Intercooler looks awesome as does everything else.
-Jimlab
-Blake motherfucking McBride
Offline GSXRATED
« Reply #77 on: October 22, 2012, 08:34:00 AM »
To make a long story short, I had ID2000's but they were stolen. At the time I could not afford to buy them again, so I just went with the 1000's to have something. I am still on the stock bottom end currently, so if I end up keeping this engine setup and building the bottom end, I will likely step back up to the 2000's. For fuel I was planning on E85 (my own blend with E98 and 93 octane).
Thank you sir. I would change a few things if I were to build it again from scratch, but I am pretty happy with the outcome.
2004 Mazdaspeed Miata
2011 BMW X5 35D
1995 Toyota Supra TT Hardtop
2005 CRF450X: Supermoto
Offline Azar
  • And runnin, runnin...and runnin, runnin
« Reply #78 on: October 22, 2012, 04:49:09 PM »
 :o
How did I miss this build??
A+++ Would read again.
Offline GSXRATED
« Reply #79 on: December 03, 2012, 10:18:59 PM »
A few updates:
I powder coated my modified water outlet in wrinkle black, along with the charge pipes.  Welded on my Tial Q BOV flange and installed that as well.  I also finished my upper and lower radiator lines and installed my turbo oil lines (wrapped in DEI heat sleeve).  Then I made some upper radiator mounts and welded those onto the radiator.
2011 BMW X5 35D
« Reply #80 on: December 04, 2012, 12:17:39 AM »
Looks great.   I'm a big fan of wrinkle black.
Offline WannaBeFast
  • Single and Looking
« Reply #81 on: December 04, 2012, 12:23:05 AM »
This is pimp I tell you.
Offline Sho Amo
« Reply #82 on: December 04, 2012, 05:15:46 AM »
I agree with the two above. There's something classy about wrinkle black. Oh and that intake manifold looks great.
[Sold] '90 GTU LS1/t56
Offline GSXRATED
« Reply #83 on: December 04, 2012, 07:48:15 AM »
Thanks guys. I agree about the wrinkle finish. It really makes the parts look OEM in my opinion. I initially had planned to polish more parts, but I really liked the contrast between the white bay and the black engine pieces.
2011 BMW X5 35D
Offline N2v8fcs
« Reply #84 on: December 05, 2012, 07:53:53 PM »
nice work as always!
:drive:
Offline GSXRATED
« Reply #85 on: December 09, 2012, 07:35:30 PM »
Vacuum block installed and push-to-connect hose ran to intake manifold, FPR, and BOV.
Belt tensioner cleaned up & painted, and installed a 6-rib pulley & shorter belt to account for my lack of A/C & PS.
I also built a catch can and put my down pipe in place.  I need to finesse the angle of the turbo slightly so the charge pipes and exhaust line up to where they should be.  Getting closer to the first start up!
« Last Edit: December 09, 2012, 08:04:14 PM by GSXRATED »
2011 BMW X5 35D
Offline GSXRATED
« Reply #86 on: December 12, 2012, 10:24:16 PM »
Ran a couple of lines, and my air filter I ordered showed up.  I also adjusted the turbo orientation and clocked the compressor slightly so everything lined up like I wanted it to:
« Last Edit: March 10, 2013, 12:02:05 PM by GSXRATED »
2011 BMW X5 35D
Offline GSXRATED
« Reply #87 on: March 10, 2013, 12:07:22 PM »
Had a chance to work on my trans cooler mount. Sorry for the iphone pics:
Still working on my catch can location & line routing:
I have now topped off the oil, trans fluid, and added coolant.  I just need to do a functionality check with the ECU, finish the trans cooler lines, and tie up a couple of loose ends before the first start up.
2011 BMW X5 35D
Offline Demon
« Reply #88 on: March 10, 2013, 12:17:53 PM »
Nice!  Engine bay looks awesome!
Offline MDoe8
« Reply #89 on: March 10, 2013, 02:19:54 PM »
interesting trans cooler location, I may have to replicate that.  Have any more pictures of that?  How is the airflow going to be with it there?
Dodge Stealth LM7 Twin Turbo
