March 30, 2025, 02:57:27 AM
Author Topic: 1994 RHD R2 Project: 2JZGTE/TH400  (Read 44196 times)
Re: 1994 RHD R2 Project: 2JZGTE/TH400
« Reply #60 on: May 18, 2012, 09:09:44 PM »
Ooooooh, shiny.
Offline FC3S Murray
« Reply #61 on: May 19, 2012, 02:40:35 PM »
SRM Performance Tuning LLC
Offline Jarhead Steve
« Reply #62 on: May 20, 2012, 11:29:25 PM »
straight fugly
Devin, learn how to build a car already.
88 528e-DD
http://www.carclubvt.com/
Offline GSXRATED
« Reply #63 on: May 23, 2012, 10:44:51 AM »
straight fugly
I don't think I can ever live up to your standards Steve.
2004 Mazdaspeed Miata
2011 BMW X5 35D
1995 Toyota Supra TT Hardtop
2005 CRF450X: Supermoto
Offline GSXRATED
« Reply #64 on: September 30, 2012, 10:10:20 PM »
4 month update:
Installed the magnafuel FPR, polished & installed the fuel rail, and installed the ID1000's.
I also put in some heat reflective foil, installed my brake proportioning valve, and ran the line from the valve to the factory rear brake line.
2011 BMW X5 35D
« Reply #65 on: September 30, 2012, 10:37:45 PM »
Looking good.
Offline Scottie-GNZ
« Reply #66 on: October 01, 2012, 12:38:56 AM »
Awesome build. BTW, some time ago I had my FPR on the firewall of one of my cars and the local track told me I had to relocate it. If you plan to run the car, might want to check with the track before you get further into the build.
Scottie
8.71 @ 156.79
« Reply #67 on: October 01, 2012, 10:19:00 AM »
I dig the finish on the manifold and cover
Offline GSXRATED
« Reply #68 on: October 01, 2012, 02:58:38 PM »
Looking good.
Thank you sir.
The track I usually run at is pretty slack to be honest, but that is a good point. I will double check on the exact rule. I know there is a gap by running non shielded braided fuel line in the engine bay passing by the flywheel as well that I may need to address. I appreciate the heads up.
Thanks. I had other plans initially, but decided to go with wrinkle black in the end. I think it came out better than I had imagined.
2011 BMW X5 35D
Offline mefarri
« Reply #69 on: October 01, 2012, 03:10:45 PM »
Super clean as usual.
-Jimlab
-Blake motherfucking McBride
Offline nasty2jzfd
« Reply #70 on: October 03, 2012, 06:05:16 AM »
I still would have gone 4l80e any day over TH-400
Offline nofxrxmxpx
« Reply #71 on: October 03, 2012, 10:54:44 AM »
Where did you get the gold heat reflector? I need!
the candy is dandy
Offline GSXRATED
« Reply #72 on: October 03, 2012, 11:28:54 AM »
For a mostly track driven car? I would agree if I wanted OD, or intended to mostly street drive the car, but I got a TH400 for the lower cost, smaller size, and lighter weight, tons of spare parts available, and no wiring necessary (save for the brake).  I would have gone PG, but I wanted to occasionally drive it on the street to local shows.
Pegasus racing carries it.
2011 BMW X5 35D
Offline r71
« Reply #73 on: October 03, 2012, 01:23:55 PM »
Holy crapola, three thumbs up!
94 FD
LS1 from 04 GTO
In Progress.....Almost done... Almost...
Build thread: http://www.norotors.com/index.php?topic=8308.msg116732#msg116732
Offline GSXRATED
« Reply #74 on: October 21, 2012, 07:55:52 PM »
Got the header mounted with some ARP M10x1.25 stainless hardware, mocked up the turbo oil lines, installed the wastegate & dump tube, and put my throttle body back on:
I also finished up my fuel lines and had a chance to pressurize the system and check for leaks (had to use my phone to record video since I couldn't see the gauge and provide power to the pump at the same time.  This is the sound of the Magnafuel MP 4301, lol:
2011 BMW X5 35D
