March 18, 2025, 05:24:17 PM
Author Topic: AHarada's build thread  (Read 71424 times)
Offline FC3S Murray
Re: AHarada's build thread
« Reply #180 on: March 18, 2023, 12:11:54 AM »
I haven't touched my barbell yet.....it's not leaking yet but it always crosses my mind.
Nice updates. How have you been man? You ready to be a civilian yet?
SRM Performance Tuning LLC
Offline AHarada
« Reply #181 on: March 19, 2023, 06:13:41 PM »
I’ll be ready to be a civilian in just 9 years! Lol crazy how time flies. It’s also crazy how little I drive this car. I think I’ve only put a few thousand miles on it since I’ve owned it over the last 15 years or so.
I used a machined aluminum alignment tool when I reinstalled the rear cover. Definitely a must have when removing it. My rear main seal was leaking pretty bad and the rear cover was leaking at the top also, so it was definitely necessary to pull it. The barbell was just a convenient mod to do while I was in there.
[smg id=6954]
Offline AHarada
« Reply #182 on: June 05, 2023, 04:13:29 AM »
My engine bay was looking pretty rough so I did some work on cleaning up the engine bay. I’ve gone to a few local car meets, and naturally everyone always wants to look under the hood. Welded up some holes, body filler, paint, re-ran some some wiring for cleaner routing, and got some carbon fiber fender hole covers. Also switched to a different ABS delete kit from full detail automotive. Their kit uses some soft lines, but it gives the cleanest look in the engine bay.
Got some new Continental extreme contact sport 02s. Put the car on scales to corner balance, but surprisingly the car was pretty dialed in to start, so just did an alignment.
Re-did a bunch of wiring in the interior. Changed audio setup, different battery, and everything gets covered up nicely.
My stock FD oil cooler has been leaking despite several attempts to fix the leak. I changed it out for a Mocal unit with Banzai racing brackets. The brackets are very sturdy and makes for a very clean install. Made some ducting out of plastic sheet, and also made some for the radiator while I was in there.
I have some track days coming up that I am signed up for. Should be good times.
[smg id=6954]
Offline AHarada
« Reply #183 on: June 05, 2023, 04:15:08 AM »
1
[smg id=6954]
Offline AHarada
« Reply #184 on: June 10, 2023, 04:34:50 AM »
I took the car for a one day high performance driving course at Proformance in Kent WA at Pacific Raceways. The morning consisted of a little bit of classroom talk with Don Kitch. The Art of driving in the rain was a book and a movie about him. Then we took the cars out for some drills in the morning, followed by course familiarization laps with instructors, and finally several sessions of track lapping with instructors. It was a great time and it felt amazing to really push the car in a controlled environment. That was the most fun I've had with the car over the 15 years that I've owned it and it kind of reinvigorated my love of the FD. I also learned a lot about what the car can do.The instructors and other drivers were all pretty happy to see an FD on track, and they were also pretty impressed with the swap. Some notes from the track sessions.
Engine: I had more than enough power all through the entire rev range. The car is very fast, and the mid-range torque coupled with the lightweight car made it effortless to get the car moving fast. I was shifting at 5k for most of the track, and I never felt the need to wind it up higher. Except for the long straight where I was redlining 4th gear. The EWP setup did fine and my coolant temps were controlled all day long. The oil was getting hot, and I was seeing 260+ throughout the sessions. I ordered another of the same oil cooler to add to the passenger side, and I'll do the ducting the same way. I had a lot of oil consumption throughout the day. My catch can caught several ounces, and I was down about a quart of oil by the time I got home. One of the track workers mentioned he was seeing a small puff of smoke when I was decelerating from the long straight going into the first sweeping corner. I'm wondering if I am burning oil because of PCV despite having a catch can, or if it is something else?
Suspension: I had the coilovers set pretty soft to start, but later stiffened them up a good amount to get more response and to control body roll. I have 8/6kg springs front and rear, and they seemed to work okay, but may be on the soft side for track usage. They are nice and comfortable on the street though. The car handled great with stiffer shocks settings, but I may have set them a little too stiff because I think I lost some compliance on some bumpy sections. Maybe in the future I'll look into stiffer sway bars to allow more response and less body roll so I can set the shocks a little softer. With the amount of torque that I have, I could definitely feel the weight transfer to the rear under acceleration and the rear squat under power. Would 10/8kg springs help to reduce the squat?
Tires/brakes: The Continental ECS 02 felt good on track for being a tire that is a compromise between street, track performance, and wet performance. They had lots of grip and I could feel the feedback through them when I was pushing them hard. I run a square 255/40/17 all around at the moment. I never felt any hint of understeer; I think I would like to run a wider tire in the rear on my next set to go faster. The RZ brakes that I have all around performed great. I repeatedly and consistently slowed the car adequately throughout the sessions without any degradation in braking performance. I am running stock Mazda pads, and I actually didn't have any brake fade. I thought I might need some more aggressive pads for track days, but I was surprised that the stock pads survived all of the abuse and maintained bite all day. Perhaps as I get to be a faster driver and my car gets more dialed in, I'll need better pads. Since my ABS is deleted, I now have an adjustable prop valve for the rear brakes. I have it set in the middle of it's range right now, so I guess that means 50% flow, and I'm not really sure if I need any adjustment. Part of the drills in the morning was ABS engagement, or in my case locked up the brakes, then recovering from it. The car seemed to do fine, so I guess I'll just leave it?
Interior: My 330mm Sparco steering wheel covers up my gauges pretty bad. On the street, it's not a huge deal as I can just move my head to see them, but at the track with all of my attention focused on driving, the steering wheel is really masking the tach and speedo. My shift light on my speedhut tach is still visible so that is nice and I didn't see a real need to look at my speedo, but it would still be nice to be able to see them if I wanted to. I ordered a Personal Grinta that is 350mm, so hopefully that allows me to see them. My metering hood is carbon fiber wrapped, but it causes some glare. I want to repair or replace the metering hood to stop it from rocking back and forth (broken tabs), and maybe do some flocking on it. The stock seats seemed to work okay, but I think a bucket seat would work even better. There was one corner in particular with elevation change that I was putting effort into staying planted in my seat. I think a bucket seat would give me a more planted seating position, hopefully lower in the car, and maybe provide more feedback from the car. My oil temp gauge currently maxes out at 260. Not that I want to go above that, but when I reached 260 during lapping, I was blind to what my actual temps were. I may upgrade to a 300 degree gauge at some point, but hopefully my additional oil cooler keeps me under 260. The Lizardskin coating that I did in the trans tunnel has been working great. It doesn't seem like much if any heat gets transmitted into the cabin. Before that, it used to feel like I was getting baked.
I have 2 more track days lined up this month at the Ridge in Shelton, WA which I am looking forward to. The car is going into storage after that for a few years while I live overseas again, but I'm glad I'm getting to enjoy the track days now while I can.
« Last Edit: June 10, 2023, 04:45:45 AM by AHarada »
[smg id=6954]
« Reply #185 on: June 14, 2023, 03:06:07 PM »
sounds like a fun time, what were your oil pressures like?  260 seems hot to me for oil, I'd prefer 220 at max heat soak.
Offline nadeem
« Reply #186 on: June 14, 2023, 07:24:19 PM »
220 is Pretty Much Where My Coolant and Oil Temperature Gauge Stays at.
On Really Hot Days - The Coolant Temperature gets to 225.
Offline AHarada
« Reply #187 on: June 15, 2023, 04:22:54 PM »
I did another track day, this time at the Ridge in Shelton, WA. It is significantly more complex and nuanced vs Pacific raceways. I had a driving coach all day whom is also an FD owner, and I was able to make huge improvements through the day.
The night before this track day, all of the parts to install a second passenger side oil cooler made it in so I scrambled to install it. I didn’t have time to do any ducting, but the banzai bracket puts them pretty close to the 99 oil cooler openings anyway. I also got in some Hawk DTC 60 front and rear which I also threw in the day before; they did great on track for me.
My oil temps were still getting up to 260 plus on hot laps. They crept up slower this time and came back down quickly if I let off to cool down for a bit. Talking to some other LS track guys there and an LS6 user in particular, it seems it is not uncommon for them to get their oil temps up towards 300 degrees. With a larger capacity oil filter and 2 oil coolers and lines, my oil capacity is somewhere close to 8 quarts.
With my oil temps high coming off track, my idle oil pressure was around 27. At a more normal operating temp of 220, my oil pressure is around 32.
Are you guys seeing 220 oil temps with heavy track usage? If so, what oil temp controls do you have installed?
[smg id=6954]
« Reply #188 on: June 16, 2023, 08:56:01 AM »
I am running an LT1 so not apples to apples, with drifting I probably get to a max of 240 but I always have cool down time while I am waiting in line.  My clearances on my main bearings are pretty loose, hot idle oil pressure is around 25 psi but builds to 60 psi at around 2000 rpm.  I run a high pressure oil pump with stock volume.  I also have an 8qt oil pan, and 25 row oil cooler with no ducting in front of the radiator and a 180 degree thermostatic filter adapter plate, I run -10 AN lines, what size line do you run?
« Reply #189 on: June 16, 2023, 09:48:11 AM »
Did you feel the oil coolers by hand at all?  I can't believe you are heating to 260 degrees if they are working properly.  There may be a bypass in them and if they don't feel 260 degrees it may be worth looking into.
Your write up sounds like a typical car journey from street car to race car LOL.  Clearly define your goals with the car (% street/track) and have fun with it!!
Offline Esser
« Reply #190 on: June 16, 2023, 10:23:10 AM »
260 is fine, and i would expect that on a hard track day. Sometimes it just levels out around there when cooler is working all out.
Prolonged 290 is a concern
Offline AHarada
« Reply #191 on: June 25, 2023, 03:15:33 AM »
On track at the ridge
[smg id=6954]
Offline paul_3rdgen
« Reply #192 on: June 25, 2023, 01:01:10 PM »
Looking good!  Nothing like hitting the track and everything working like it should.
I was at the track last week, my oil temps hit 235 degrees close to end end of my 20 min session, I don’t have any oil coolers but I am running a drysump with 10 quarts of oil.
« Last Edit: June 25, 2023, 01:35:38 PM by paul_3rdgen »
93 RX7 R1 500rwhp
LS2, H/C combo... ARE drysump
