March 18, 2025, 05:24:24 PM
Author Topic: AHarada's build thread  (Read 71426 times)
Offline Jordan Innovations
    • Jordan Innovations
Re: AHarada's build thread
« Reply #150 on: December 20, 2011, 03:10:23 PM »
That's awesome!  Super happy for you!
The car died today once.  The idle dips really low when braking at times.  I'm not sure why the idle likes to dip, could it be a tuning issue?  When the car died it reminded me that I have not put a check valve in the brake booster vacuum line yet  ::)
I was just going to say, sounds like you don't have a check valve in the booster.  They all leak, they all need check valves!
Offline halfspec
« Reply #151 on: December 20, 2011, 03:37:15 PM »
Damn! That's one thing I don't have either! I'll have to get one ASAP :)
Lane
« Reply #152 on: December 20, 2011, 08:47:32 PM »
If your booster leaks, it will be a vacuum leak even with a check valve, it just won't be a boost leak.   Unless you install the check valve backwards.
Offline FC3S Murray
« Reply #153 on: December 21, 2011, 11:04:16 AM »
My idle would dip low to when coming to a stop. I put in a check valve and that cleared it up, this was when i first got the car done and on the road. BUT every time i reset my battery circuit breaker the pcm has tp relearn the idle and that takes about 20 miles to sqaure out and then it sits and lobes perfect.  May be your case too unless you have already put some mileage on it
SRM Performance Tuning LLC
Offline AHarada
« Reply #154 on: December 21, 2011, 01:30:48 PM »
I think you are right FC3S Murray.  I set the alarm off in a parking lot so i just cut the battery.  After that was when the idle issues came.  After driving it around for a while, the problem has not come back.
[smg id=6954]
« Reply #155 on: December 21, 2011, 03:50:27 PM »
Yeah, totally different causes, same basic result.
Offline FC3S Murray
« Reply #156 on: December 22, 2011, 01:52:19 AM »
Glad i could help man.
Offline wompa164
« Reply #157 on: January 13, 2012, 11:44:23 AM »
Can someone link to the check value that they purchased and used in their build?
Offline AHarada
« Reply #158 on: January 19, 2012, 07:07:35 PM »
Took my car to Cunningham motorsports today.  Got a full tune and everything went smoothly.  Put down 410whp and 383wtq.  Not bad for a baby cam that's quiet, low emissions, rock solid idle at 850rpm, and should get decent gas mileage.  I ran out of injector, so an upgrade is next for the motor.  The tech said I have the quiestest swapped car he had ever heard.  They liked the cam and setup.
https://www.youtube.com/watch?v=9PRV2duDYMc&feature=youtu.be
00' Fbody LS1
untouched GTO 243 heads
LS6 lightweight valves
Nitrided beehive 1518 valve springs
LS6 intake manifold
KaTech rod bolts
EPS spec cam 222/226 .597" .598" 115LSA  3
No power steering/AC
25% UD balancer
Truck 2 wire alternator
Samberg intake filter V2
JTR 1 3/4" long tubes
2 high flow cats
Tanabe medallion exhaust
I'll need to get some better tires soon.  Hopefully I'll be able to stick with the 3.90 rear and some sticky street tires.  The car is going in storage after the weekend so there won't be any progress until then.
[smg id=6954]
Offline AHarada
« Reply #159 on: January 19, 2012, 07:12:03 PM »
Dyno sheet
[smg id=6954]
Offline ltsr
« Reply #160 on: January 19, 2012, 07:24:07 PM »
Nice! and I think my stock LS1 is enough.. yeah right. The car is probably scary to drive on the streets. Which UD pulley do you have?  :drive:
///M
« Reply #161 on: January 19, 2012, 08:34:33 PM »
Great curve.  Why is the car going in storage again?  I mean sure, it's been unseasonably cold the last week or so, but cmon this is socal!
Offline AHarada
« Reply #162 on: January 19, 2012, 09:13:10 PM »
It's been a little while since I bought the pulley, but I'm pretty sure I got the SLP.  1st through 3rd just blows the tires off, definitely need better tires  :drive:
« Last Edit: July 25, 2017, 06:46:34 AM by AHarada »
[smg id=6954]
« Reply #163 on: January 19, 2012, 10:12:32 PM »
Oh, excellent, now's not a bad time to be down there :)
Keep your head up, it's a cakewalk.
Offline mdpalmer
« Reply #164 on: January 23, 2012, 07:33:54 PM »
That torque curve is ridiculous. Great power out of that thing dude!!!! Amazing on stock heads too!
Mike
My Build Thread
YouTube Vids
