March 17, 2025, 01:35:06 AM
Author Topic: First Start LS1 NIGHTMARE!!!!  (Read 8020 times)
Offline chrispypunk86
Re: First Start LS1 NIGHTMARE!!!!
« Reply #15 on: February 03, 2013, 04:17:45 PM »
ouch man... my first start resulted in catastrophic failure as well... not fun.
Really what happened with yours?
Offline Andrew R
  • Superunnatural
« Reply #16 on: February 04, 2013, 07:07:43 AM »
Aluminum oxide blasting material in the oil pan seems to have been the culprit -however during the rebuild I found a oil control plug that was shot -either way -I lost ALL the bearings and oil pressure after about 20 min of running it.
« Reply #17 on: February 04, 2013, 04:22:45 PM »
Buy a used piston with complete con rod from here or ls1tech.com and slap that sucker back together.
For the cost of the Stg 2.5 heads you can pay a little more and have NEW TFS 220cc as cast heads which are a lot better.
Offline mattster03
« Reply #18 on: February 04, 2013, 05:07:40 PM »
Looks like an M6x1.0 to me.    ;)
This.  And it looks like about the right length for a Valley Cover bolt to me.
Offline ncaudio
« Reply #19 on: February 04, 2013, 05:53:04 PM »
Bummer
'88 FC LS T56, 94 FD LS T56, '93 FD was LS turbo T56 Ford 8.8 IRS Ablake's old car (project)
« Reply #20 on: February 04, 2013, 06:15:18 PM »
Actually thats what I was gonna do until I found a hairline crack in sleeve and block. :(
« Reply #21 on: February 05, 2013, 02:56:08 PM »
I'm selling an '01 5.3 with around 50K miles for $800.  It is a long block.
« Reply #22 on: February 05, 2013, 05:08:14 PM »
Thanks but I think im gonna go with a ls1 with 20k miles on it.
« Reply #23 on: February 07, 2013, 10:36:37 PM »
Where at on the block was it cracked? Same area around#4 or  totally different spot?
« Reply #24 on: February 08, 2013, 06:19:46 PM »
It cracked along the same cylinder.
