March 18, 2025, 03:16:54 AM
Author Topic: Mikes 03 cobra powered 88 fc drift car build  (Read 68954 times)
Offline jerel saxon
Re: Mikes 03 cobra powered 88 fc drift car build
« Reply #75 on: February 13, 2013, 07:06:50 PM »
you my friend have the best engine swap of all time :D. if i had the money id do it but my budget only permited a sbf when i become rich and famous i want a set of the mounts keep up the good work.  THAT WING IS SICK :bacon:
If your having rotary problems i feel bad for you son I got v8rx7 and the bitch still runs :P
1988 rx7 gtu ford 302 HO carbureted tremec t5 grannyspeedshop kit
Offline 88svtFC
« Reply #76 on: February 14, 2013, 02:50:14 AM »
thanks man!!! I love this motor too:)
Offline 88svtFC
« Reply #77 on: February 14, 2013, 04:37:21 AM »
just picked up a set of comp extreme energy stage 3 blower cams for the beast:) Should sound like pure sex at idle
[attachimg=1]
Offline 88svtFC
« Reply #78 on: February 14, 2013, 05:01:26 AM »
sky view
[attachimg=1]
Offline screamin88
« Reply #79 on: February 14, 2013, 06:53:22 AM »
Throbbing.
Offline jerel saxon
« Reply #80 on: February 14, 2013, 10:17:02 AM »
 :D cams are fun what are the specs. have you ever thought of get the gear conversion might add some more noise to that screamin beast
Offline clocker
« Reply #81 on: February 14, 2013, 08:37:15 PM »
More details on the dash, please.
How does it bolt in, what are you doing about ducting, what's it out of...that sort of thing.
Offline jerel saxon
« Reply #82 on: February 14, 2013, 11:17:10 PM »
i also am intrested in the in the dash swap i have 2 sn95 mustangs. also more info on the brake booster i have a 4.6 sohc non pi shell dash engine trans and wire harness and i have a gutted fc and would be intrested in making the 2 a pair so the more the better. do you think the mounts you made would work?
Offline ALLslowNOshow
« Reply #83 on: February 15, 2013, 12:25:52 AM »
Are you using a Mustang steering column also?
86 GXL - LQ9/T56
Offline jerel saxon
« Reply #84 on: February 15, 2013, 12:49:45 AM »
I got one havnt decided yet tho  :scratch: . How easy was it
Offline 88svtFC
« Reply #85 on: February 15, 2013, 02:07:36 AM »
Sct tuning stuff came in today:)
[attachimg=1]
Offline 88svtFC
« Reply #86 on: February 15, 2013, 02:37:27 AM »
Comp Cams Xtreme Energy" Stage III Camshafts
- RACE Limited street use profile.
- Basic Operating RPM Range: 2,200-6,500 RPM
- Requires larger t-body, mass air, injectors and exhaust
- Requires lower gears and custom programming
- New valve springs required
- Very Rough Idle.
Grind Number: XE274BH-116
RPM Range: 2000-6400
Intake: 238 deg @ .050/.475" lift Exhaust: 240 deg @.050/.450" lift 116 LCs
Offline 88svtFC
« Reply #87 on: February 15, 2013, 02:45:46 AM »
If your talking about ac/heater vent work I deleted all that since this is a all out race/drift car. The fittment to the windshield was done by laying the rx7 dash defrost piece up to it to make your cut lines...I used a air die grinder to cut the dash to fit against the windshield, very little needs to be cut. Then I just made my mounting tabs which ill post up some pics of that as soon as I pull the dash out again. Width wise the dash fits perfect!
Offline 88svtFC
« Reply #88 on: February 15, 2013, 02:55:07 AM »
Yes my mounts will work with your sohc 4.6 since all mod motor sohc 4.6,5.4, and dohc 4.6,5.4 use the same mounts. For the brakes I used the hydroboost and matching 01 mustang 5 speed pedal box... re-drilled the fire wall and bolted them up since they sandwich themselves together. For the clutch cable I drilled the fire wall and notched the inside of the body for the clutch cable quadrant clearence as you can see in my pics.
Offline 88svtFC
« Reply #89 on: February 15, 2013, 03:01:21 AM »
Yes Im using the 01 mustang steering column...bolts right up to the mustang dash. For the steering shaft I merged the rx7 steering shaft to the mustang, ill get some pics of it.
