Comp Cams Xtreme Energy" Stage III Camshafts
- RACE Limited street use profile.
- Basic Operating RPM Range: 2,200-6,500 RPM
- Requires larger t-body, mass air, injectors and exhaust
- Requires lower gears and custom programming
- New valve springs required
- Very Rough Idle.
Grind Number: XE274BH-116
RPM Range: 2000-6400
Intake: 238 deg @ .050/.475" lift Exhaust: 240 deg @.050/.450" lift 116 LCs
cams are fun what are the specs. have you ever thought of get the gear conversion might add some more noise to that screamin beast
