March 18, 2025, 04:14:46 AM
Author Topic: fd3sls3 build: 416 stroker....56k take a nap  (Read 16684 times)
Offline fd3sls3
Re: fd3sls3 build: 416 stroker....56k take a nap
« Reply #15 on: January 03, 2013, 12:25:10 PM »
The headers would have cleared with no issue with a standard bellhousing...unfortunately ..the quicktime maintains the diameter all the way around- which doesnt accomodate for long tubes (i cant speak for mid-length, as they had already been sold).  Ill upload a picture later of the clearancing with the quicktime- it will better explain where its tight.
As for the brake booster hose, i was able to "massage" the firewall to make a nice transition with the rubber hose- no sharp bends, though it does touch the firewall. (Remember- its solid mounted-movement is nill)
I opted to run the MAP in the front, i made a bracket to secure it to where the throttle cable normally bolts to, and ran silicone hose from it over to the nipple on the front drivers side of the fast 102.
I will try to post up a video as well later today.
Offline fd3sls3
« Reply #16 on: January 03, 2013, 12:27:28 PM »
Hopefully noone is still running a 56k.....   lol
Offline fd3sls3
« Reply #17 on: January 03, 2013, 01:11:06 PM »
A couple videos added...
Offline jasonv31
« Reply #18 on: January 03, 2013, 01:29:00 PM »
Wow.  Amazing build... one of the better on the drivetrain.  :-)
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Offline fd3sls3
« Reply #19 on: January 03, 2013, 05:19:18 PM »
Thanks!  I stuck with the FD diff as I had already installed the KAAZ 1.5 way, so I bought a set of 3.90's to help out.  I'm hoping it will hold up, I'm thinking between the Samburg diff mount and 300M axle bars, I "should" be good (not running slicks ever).  I intend on occasionally running the 1/4 (on street tires, as I only care what it can do from a daily standpoint).  The car was more intended for the occasional track-day/ weekend cruiser.  I have only put 1K miles on the setup before the dreaded snowfall in central NY, I do want to re-check my drive-line angles (notice the increasing drive-train noise around 155 mph+), I'm assuming that is the culprit, though I know the diff mount will send resonation through the body of the car- anybody who has experienced a similar situation, please chime in!
Offline Jordan Innovations
    • Jordan Innovations
« Reply #20 on: January 03, 2013, 10:56:17 PM »
Great, great powertrain, very similar to what some of the race cars we help out are running.  With an investment like that I'd hope you're at least going to put an Accusump on it.
Sounds amazing, and that 65-170 run was great, 4th moves the fuck out haha.
I'm also running a Kaaz diff that I actually pulled out of a 7yr old race car, they hold up to power great.  I'm interested to see what you find on the driveline vibrations, could be ring gear wear, but could also be the fact that the engine and trans are solid mounted and the diff is bushed front and back... I'd solid mount that sucker.
« Reply #21 on: January 04, 2013, 03:19:08 AM »
nice build!
What does it MPH in the 1/4?
Offline fd3sls3
« Reply #22 on: January 04, 2013, 05:47:31 AM »
I still need to do an accusump....hopefully over the winter ...(i had all i could do to get some miles on it before snowfall).  It pulls pretty good...the diff is mounted with delrin on the rear points and poly (IIRC) on justins brace...ill have to make something for at least the front one ...i think the delein is solid enough (thoughts?).
I have no idea what it currently traps at.....all of the tracks where closed for the winter by time ot was out...lol.... ill have a # this spring for sure!
Offline FC3S Murray
« Reply #23 on: January 04, 2013, 08:11:29 PM »
.......speechless.   :cheers:   :drive:
MAN, that thing must feel INSANE. How shocked were you first time you went WOT when compared to your old LS2 set up?
SRM Performance Tuning LLC
Offline fd3sls3
« Reply #24 on: January 04, 2013, 09:25:56 PM »
Thanks!, Honestly-as stupid as it sounds, its hard to say.  The car was down for 1.5 yrs after the blown engine.  It definitely feels faster, but i wish I had a back-to-back drive!  1/4 trap speed will say alot.......spring cant come soon enough!!
Offline fd3sls3
« Reply #25 on: January 09, 2013, 10:20:58 PM »
Added a corner-weight photo. Note: #s represented are car (with 1/3 tank of fuel)+  myself (170#) +passenger (210#)... wanted to see how that affected bias...
Offline thetastelingers
« Reply #26 on: January 10, 2013, 11:55:13 AM »
Great build. Sorry to hear you put the LS in and it not even getting the mileage that the rotor did.
wazzaaaaaaaaaaaapppppp!
Offline fd3sls3
« Reply #27 on: January 10, 2013, 08:00:30 PM »
I assume your talking about mileage per engine... not MPG.... yea, it sucks.... guess it comes with the territory. Hopefully the new engine will last...    pretty sure i fixed the oiling issue the prev engine had....   I enjoy working on it-for the most part (though my wallet doesnt)
Offline Demon
« Reply #28 on: January 10, 2013, 08:10:25 PM »
VERY nice setup!!  That thing must be a blast to drive.
I'd guess you'll trap between 138-142, err on the higher side of that.
I see a 8.8 setup in your future!! :)
Offline FC3S Murray
« Reply #29 on: January 11, 2013, 12:58:58 AM »
Lol I thought the same thing last time I posted. Be interesting how long his Mazda ass lasts.
