March 18, 2025, 02:41:07 AM
Author Topic: Tranny Shield  (Read 4871 times)
Offline rex388
Tranny Shield
« on: November 30, 2012, 12:06:17 AM »
What tranny shield are you guys running. I am just thinking while at work and I think the only one that will work is the csr composite one cause of how tight it is wrapped against the tranny itself.
More directed at the fc guys.
Offline jim3
Re: Tranny Shield
« Reply #1 on: November 30, 2012, 02:03:21 AM »
I need to do this.  It is very tight in the tunnel, no doubt.  A little off topic, Digitalsolo has a driveshaft loop?
You can make a barn door fly with enough horsepower.
Retirement at last.  Wife's not happy, I bought a '66 Rustang instead of paying off my F150.
Offline rex388
Re: Tranny Shield
« Reply #2 on: November 30, 2012, 02:05:46 AM »
For mine I used a moroso drive shaft loop and just cut to fit. You also going to be running a th400 by chance Jim?
Re: Tranny Shield
« Reply #3 on: November 30, 2012, 08:58:11 AM »
I have been around one of csr flexplate/tranny shields, hated that pos
I wouldnt trust a blanket type either, on bullet there are pics of tran blankets installed correctly and and it can still cut the straps when it lets go
My opinion would be an aftermarket sfi bell, that way it doesnt take up any more room than now where space counts (firewall area).
And then run a hard shield over the transmission, great plenty of room in the tunnel with a hard shield on,
Offline rex388
Re: Tranny Shield
« Reply #4 on: November 30, 2012, 09:18:37 AM »
Re: Tranny Shield
« Reply #5 on: November 30, 2012, 09:38:00 AM »
yeah if you want tight where there is no room.... buy that
Offline rex388
Re: Tranny Shield
« Reply #6 on: November 30, 2012, 09:56:38 AM »
Ya cause even if I ran a jw bellhousing I would still need a tranny shield wouldn't I?
Re: Tranny Shield
« Reply #7 on: November 30, 2012, 10:23:34 AM »
Yes with a belle you need a tran shield still
But the shield is no big deal, tons of room back in the tunnel where that is at
Using the jw bell is what saves you the critical room over running a standard flex plate shield or that csr setup
Not that much more overall $$, better setup Anyway
Offline BlnLs1/rx7
Re: Tranny Shield
« Reply #8 on: November 30, 2012, 03:19:45 PM »
After switching my powerglide case to a Reid case I was no longer required to use my TCI shield and still have it if you need one.
Offline rex388
Re: Tranny Shield
« Reply #9 on: December 01, 2012, 04:12:03 AM »
What the part # of it and how was the fitment?
Offline BlnLs1/rx7
Re: Tranny Shield
« Reply #10 on: December 02, 2012, 07:10:56 PM »
It is a TCI shield that bolts on the top for a Powerglide.I had no issues with fitting.
Offline BlnLs1/rx7
Re: Tranny Shield
« Reply #11 on: February 28, 2013, 08:22:19 PM »
Are you running a powerglide?
Offline rex388
Re: Tranny Shield
« Reply #12 on: February 28, 2013, 08:23:45 PM »
Negative. And I already picked one up for my th400.
Offline BlnLs1/rx7
Re: Tranny Shield
« Reply #13 on: March 14, 2013, 02:24:51 PM »
OK just checking.
Offline 1badimport
Re: Tranny Shield
« Reply #14 on: March 22, 2013, 12:06:33 AM »
i run a glide with a bell and a tci sheild on one trans and that csr sheild on another .the bell and tci fit better than the csr  the csr with the belt is a pain in the ass with the strap  getting near the exaust and the shift linkage i would go ultra bell and tci sheild ..
member formerly known as bluerabbit..
