March 15, 2025, 10:47:40 AM
Author Topic: Shift-S3ctor Airstrip Attack with Mike's single turbo LSx FD 11/10/12  (Read 55149 times)
Offline MyCockAddiction
  • Probationary Member
Re: Shift-S3ctor Airstrip Attack with Mike's single turbo LSx FD 11/10/12
« Reply #30 on: August 06, 2013, 12:19:17 AM »
I gotta kick outta everyone at the event touting how much boost they were running.  Conversations like, "I'm running 24 psi. Well yeah I'm running 30. That guys running 32."  Then they'd ask Mike, "How much are you running?"  He'd hold up 4 fingers and say, "About 4"
« Reply #31 on: August 06, 2013, 12:24:29 AM »
That dude is NOT running 4PSI....more like 24psi. I guess he can't count that high so he just puts up the 4 fingers....
« Reply #32 on: August 06, 2013, 01:20:43 AM »
Mmmmmm not sure if serious?
Offline PianoProdigy
« Reply #33 on: August 06, 2013, 11:10:25 AM »
Seems like trolling above, but I am too skeptical that 4ish psi making 600 rwhp can be that potent. The FD is light, no doubt, but victories against some of those opponents seem reasonably questionable when power to weight ratios are considered.
Offline Sabre002
« Reply #34 on: August 06, 2013, 11:26:52 AM »
You do realize that 24 PSI on a 6.2L V8 with heads that flow 340+ CFM would be like 1200 RWHP right.  You picked the wrong site to troll if you keep this up.
Josh
Jsmit295@mazdausa.com
« Reply #35 on: August 06, 2013, 11:56:34 AM »
PSI is (in a sense) effectively just a measure of restriction. And don't forget the aero factor.
Offline Ls1-fd
« Reply #36 on: August 06, 2013, 12:41:07 PM »
24psi on a ls9 engine would lift the heads. Car was running more than 4psi on the 193mph run. Car went 204mph at Mojave mile with 4psi and low 170mph at 1/2 mile.
Turbo LS9 RX7
Offline Ls1-fd
« Reply #37 on: August 06, 2013, 12:42:22 PM »
Next event I will have to put in one of the guys above in the car with a psi gauge in hand.
Turbo LS9 RX7
« Reply #38 on: August 06, 2013, 12:48:20 PM »
I think people just need to stop having misapprehensions about what PSI means lol...
Offline BlackSeven
  • Mike Cochran
« Reply #39 on: August 06, 2013, 01:29:19 PM »
Awwww somebodys vagina got hurt....
1994 Montego Blue Touring
1993 Brilliant Black Base Heads/Cam LS1/T56 Daily Driver. - Sold.
Offline Hugh Jasoul
« Reply #40 on: August 06, 2013, 01:30:58 PM »
PSI means pounds per square inch.  No more misconception.
« Reply #41 on: August 06, 2013, 01:36:32 PM »
Actually it means pounds of force per square inch but okay lol
« Reply #42 on: August 06, 2013, 01:38:00 PM »
Lol^
Id say it was around 14-17 for the 193
Offline Ls1-fd
« Reply #43 on: August 06, 2013, 01:52:40 PM »
Lol^
10 psi on my last run 193.5mph. I turned it up for the TT ford gt. This motor has never seen a dyno but my last ls3 made max power at 14psi with 23* timing.  People forget that the rx7 does not need that much power to go fast.
Turbo LS9 RX7
Offline Hugh Jasoul
« Reply #44 on: August 06, 2013, 01:55:35 PM »
I was way off, thanks for the correction, lol. In reality psi stands for a multitude of things and not just pounds (of force) per square inch.
You're welcome
