March 17, 2025, 03:15:58 AM
Author Topic: Forged LS1 Rx7 FC (Old school 350 to new school)  (Read 10301 times)
Offline FC3S Murray
Re: Forged LS1 Rx7 FC (Old school 350 to new school)
« Reply #15 on: November 07, 2012, 10:57:49 PM »
+1 for the single factory fan. My taurus fans pulls some serious air lol.
Look forward to this build!
SRM Performance Tuning LLC
Offline SBCFC07
« Reply #16 on: November 08, 2012, 12:58:25 PM »
sick build bro, looking forward to doing pretty much the same thing you are, SBC-LSX, good luck and looking forward to the progress!
87' FC Turbo clone
Forged 383 SBC EZ EFI,
 6spd, TII S4 diff (soon to be Ford 8.8 IRS)
420hp 460tq on the engine dyno
2009 Mazdaspeed3
1975 Honda CB750K cafe build
My other ride is a CH-47F ;)
Offline caseymhawn
« Reply #17 on: November 13, 2012, 06:17:09 PM »
UPDATE
Before i start, thanks for following me guys! It gives me motivation when I need it, aka I have been lazy these past few days haha. I finally got around to pulling out my front interior and some of the rear.  I hate dealing with old interior, I cracked a few pieces : (
Not going to lie, not looking forward to doing the wiring for the fans, ignition, etc.
Onnnnnnnn a good note, I got some bride seats to go  in it.  No they are not real : (
But they are very well made in my opinion
Offline caseymhawn
« Reply #18 on: November 21, 2012, 12:00:27 AM »
Well…. Some bad news but can be good news as well. As I was working under my car I started to look at the frame rails, I started peeling off the undercoating and I found that there was a lot of rust on my frame rails. I found a hole the size of a softball: ( And I found a rust hole in the driver side floor board. So with me finding that I started doing some thinking. At first I was done to repair and fix all the underbody. Well one thought lead to another, I ended up using my parts car (1988 turbo II shell). I ended up going this route because the under body off this car looked amazing compared to the gunmetal rx7.
The positives to the new chassis
-Perfect underbody (no rust like old chassis)
-Untouched firewall (not hacked up like old chassis)
-No hole in the trunk for fuel cell
-turbo II rear end
-All new bushings( minus subframe and diff)
-Already has the manual pedal setup
I know I’m forgetting a few things. But that is the main jiff.
Old chassis
(not bad side)
New Chassis
The good thing about switching chassis at this point, I haven’t lost a lot of time or took any steps back. Both cars are in about the same state. With the new chassis I have raised it up and put it on a rotisserie to “restore the underbody” undercoating, rust prevention, redo brake/fuel lines, etc.
On a good note I got my trans ☺ I cleaned it up a lot . I wire brushed it, used simple green, and resprayed it with EastWood fresh cast aluminum paint .
Offline Sho Amo
« Reply #19 on: November 21, 2012, 07:14:57 AM »
That old engine bay looked like it was going to take a bunch of work.
Good choice
[Sold] '90 GTU LS1/t56
Offline caseymhawn
« Reply #20 on: December 05, 2012, 11:06:27 PM »
Update:
Well I have been nonstop for about a week. I have got the underbody all coated and rust sealer sprayed. To remove the factory undercoat, I used eastwoods undercoat remover. I didn’t have too much faith in it to work well, but surprising it did a good job. I sprayed that, then wire wheeled it the undercoat off.  After all the undercoating was removed I used Eastwoods rust converter. Once that was dry I used rustoleum professional grade undercoating. I was going to use POR-15 but I didn’t want to spend the money on it to do the whole underbody. After all the body was not bad at. I also sprayed rust sealer, which will do a very good of keeping rust away.
 I have also disassembled the rear subframe and some of the front. I have all Drop engineering for the rear bushing and I replaced the front a while back with energy bushings.  Im getting ready to sandblast the rear subframe in the next few days. I may end up coating that with por-15 since it was pretty rusty and seems to be a common part to get rust easily.
(don’t worry I’m paint the green front subframe here soon haha)
I have started to run my fuel line, I am using the corvette FPR/filter. I was going to use 3/8 hard line but I already had a bunch of -6 and -8 steel braided line left over. I end up using the -8 line, with the Russell Gm hardline fitting. I was going to mount the FPR/Filter infront of the sublink, I feel uncomfortable with it so close to it. I would also like for it to be accessible if I had to do something which is why I end up putting it close to the fuel tank. And from what I have read and heard the closer it is to the pump the better it is for fuel pressure. I may be wrong.
Offline caseymhawn
« Reply #21 on: March 27, 2013, 11:51:13 PM »
New build thread coming soon :) different car , with a different set up . This one will be Continued later on .
Offline caseymhawn
« Reply #22 on: March 27, 2013, 11:53:03 PM »
