Just figured i would post up a build on a 2001 Trans Am we finished up a few weeks back. The owner wanted to see how far we could push the new setup. 800rwhp was getting close to the fuel systems max. Not to mention the cam only LS1 surviving at 20 psi. We had a handfull of dyno pulls and about 30 street pulls on 20 psi. We have since turned it down to 12 psi and the owner is enjoying everything.
Engine:-2001 LS1 80K miles
-Comp 231 239 .617 .624 113+4 lsa
-hardened pushrods
-Dual springs
-HPA Ported oil pump
Everything else stock. Heads have never been off.
Forced induction-HPA F-body Stainless turbo kit(keeps A/C and power steering)
-Turbonetics TC78
-JGS 50mm wastegate
-JGS 56mm BOV
-AIS dual nozzle meth kit
-HPA speed density tuning
Fuel system-HPA twin 255's in-tank
-60 Pound injectors
-Stock lines and rail
Drivetrain-Monster stage 3 clutch
-HPA built T56
-Moser 9 inch(spool, 3.50 gears, 35 spline axles)
Here is a couple photos before the car was done. I will try and get him to swing back by so i can get some good pictures of everything finished up.
