March 18, 2025, 05:42:51 AM
Author Topic: cleaning garage, lots of parts  (Read 4458 times)
Offline skinnies
« on: October 31, 2012, 05:56:05 AM »
Well things have changed and as much as I really hate to do this, I will be parting out 8.5 ls swap fox build. Here is a list of parts I have around the garage, more will come. PM me for pics, I will get pics added to the post soon. The complete roller will be for sale soon after it gets painted.
LS Parts
AFR 225 72CC PN 1630 heads with 2.08 intake valves  (less 1000 miles)   1900
l33 cam (great for boost)   85
truck intake with rails/injectors   25
l33 crank good   75
misc engine covers (10 bux each)
ls1 oil pan, pickup, windage   200
coil packs with brackets/harnesses   100
extra pcms 125 each
engine run stand ls motor(no harness)   300
stock rockers (full sets)   25
Truck  p/s pump and water pump          45
GAUGES
20lb boost gauge autometer   25
nitrous pressure cobalt 6174   150
coolant temp autometer   35
oil pressure autometer   50
msd shift lite 89631   100
TURBO
Precision 6766 turbos (new with used .81 exh housings)   2000
2 knock off RFL blow off valves (1 mild steel flange, one alum flange) 50
2.25 vibrant flex exhaust coupler (new)   25
Manual boost controller(cheaper one I used and worked fine)   15
turbo xs boost controller   40
gm boost noid(can use to make 2 stage boost settings)   35
3" vibrant v band assembly (new)   $55.00
oil return flanges with gaskets for t4 turbo(new)   20
3" tbolts (new)    $3 each
3" black couplers (new)   $5 each
31x12x3 front mount intercooler, 3" side inlet/outlets (new) $100
44lb injectors (less than 1000 miles)   200
mallory 4305m regulator (new)   90
jegs fuel pressure gauge   20
charging posts (new)   15
3" electric cutout by dmh (used)   150
summit breather filter (new)   10
flaming river cutout switch   60
be cool slim electric fans PN 75007 (new)   250
31x19 radiator aluminum (both outs pass side) (new)   150
rci outdated 5 point black belts   20
10lb nitrous bottle   100
bottle blanket   20
nitrous bottle heater   75
bottle brackets   20
nitrous feed line   25
nos nitrous bottle brackets(metal ones from stang, very nice)   30
nos nitrous pressure gauge and nx nitrous pressure gauge   20
MUSTANG PARTS
HO fibertrends fiberglass doors (new)   700
Custom made chromoly narrowed adjustable a arms (new used for mockup only)   250
« Last Edit: January 10, 2013, 03:13:22 PM by skinnies »
1st gen rx7 -  76mm junkyard 5.3, 8.65 at 167.9, first stock shortblock ls in the 8's!
1985 Ford LTD - 9.7 at 144, junkyard 5.3/76mm on 235 drag radials, 10.25 at 142 on street tires(no drag radials)
Offline skinnies
Re: cleaning garage, lots of parts
« Reply #1 on: November 06, 2012, 06:11:36 AM »
updated list
Offline skinnies
« Reply #2 on: November 22, 2012, 02:07:55 AM »
updated list
Offline WannaBeFast
  • Single and Looking
« Reply #3 on: November 22, 2012, 09:49:25 AM »
Any of those blankets fits a TC 76? If so I 'll get one. Let me know.
Offline skinnies
« Reply #4 on: November 22, 2012, 06:56:54 PM »
No they are for t3 turbos, not t4 turbos.
Offline skinnies
« Reply #5 on: November 24, 2012, 06:56:13 AM »
updated list
Offline skinnies
« Reply #6 on: January 09, 2013, 09:11:55 AM »
updated list, lots of new parts
Offline nofxrxmxpx
« Reply #7 on: January 09, 2013, 12:52:07 PM »
Will the TH400 mount work on T56?
the candy is dandy
Offline MDoe8
« Reply #8 on: January 09, 2013, 01:16:11 PM »
I will take the stock ls1 injectors, the poly trans mount (if it will fit a 4l80e also), the trans cooler, and possibly the accesory bracket if the price comes down a bit. Will be shipping to 80620
Also, what engine covers are you referring too?
Dodge Stealth LM7 Twin Turbo
Offline skinnies
« Reply #9 on: January 09, 2013, 01:30:05 PM »
The mount I believe will fit t56, but can't say for sure, I just used it for th400 we had.
The cooler is sold sorry.
Do you want just the acc bracket? I can sell it for $25 by itself.
front  timing cover, rear cover, valve covers, valley cover, etc.
Offline MDoe8
« Reply #10 on: January 09, 2013, 01:45:30 PM »
oh gotcha, i was thinking plastic covers.
Well bummer!  Was looking forward to the cooler.
Ok I'll snag the acc bracket, injectors, and the mount.
PM me paypal address and total amount with shipping to 80620. (if it fits it ships usps will fit everything and be cheap.)
Offline skinnies
« Reply #11 on: January 09, 2013, 01:50:56 PM »
Sending you a PM.
Offline skinnies
« Reply #12 on: January 10, 2013, 03:13:37 PM »
updated list
