I you're gonna build a 4point that bolts to the firewall (rather than weld), you'll want to put the car on jack stands, supported under the frame rails. If you allow the nose to sag when you build the bar, it should load the fore-aft members in compression once the car is on the ground. Free stiffness :-)
