February 19, 2025, 03:45:31 PM
Author Topic: UK RHD LS1 8.8 FD Gunnytron's build thread  (Read 252038 times)
Offline Gunnytron
« Reply #450 on: January 15, 2018, 01:12:23 PM »
Managed to get the fuel setup finalised (hopefully). I had to move theblukhead nut to the top side. The bulkhead fitting is now sitting a bit proud, but everything appears to be fitting well.
Offline Gunnytron
« Reply #451 on: June 25, 2018, 07:18:36 AM »
Took the car out to try and sort the ABS (see my other thread) and bucking issue. I was hoping that the bucking issue was to do with acceleration enrichment, but it didn't really make any difference.
I also STILL have an issue with my cooling system. My rad cap setup is leaking so I need to check if I have my system setup properly.
Offline Gunnytron
« Reply #452 on: August 19, 2018, 02:52:47 PM »
Two steps forward one step back.
I decided to get my rad welded up so that I didn't have to worry about my dodgy pressure cap mod leaking.
I also had a few other things I wasn't happy with such as the heater hose routing through the front bumper and the leaking crank seal thanks to ATI sending me the wrong hub.
So it was rad out so I could kill a few birds with one hammer.
I decided to hack the Hinson rad up to keep it looking clean. I will get it welded up with the addition of some tabs so that I can mount a front and rear shroud. I made the rear shroud, but I am not convinced the fan I have is going to fit after I put this on. It will also give me the opportunity to paint the rad black. I got the paint to do it years agao :)
« Reply #453 on: August 20, 2018, 07:53:11 AM »
Building cars is no fun if you're not making improvements.  :)   I think that radiator fix is a good idea.
Offline Gunnytron
« Reply #454 on: August 20, 2018, 12:35:39 PM »
True, it was the most fun weekend ibuad in a while :)
Offline Gunnytron
« Reply #455 on: August 21, 2018, 04:07:57 PM »
Got the crank shaft bolt out tonight. Always scary. It was covered in oil, so I guess it's good that I am doing this.
One thing that concerned me though is that the oil smelt of fuel quite a bit. I am hoping it is where the car may be running rich or because it's been standing a lot. Just hope it isn't blowby.
« Reply #456 on: August 21, 2018, 06:25:45 PM »
I have never changed oil in any LS that didn’t smell like fuel.
Offline Gunnytron
« Reply #457 on: August 22, 2018, 02:32:09 AM »
Mind now at ease,  thanks DS.
Offline Gunnytron
« Reply #458 on: August 27, 2018, 01:31:26 PM »
Crank pulley is off and I have cut some tabs to get welded to the rad so I can get that sorted soon hopefully.
I took off the front cover and knocked the seal out. One thing I did forget the first time round was that the are where the seal sits is damaged. In light of the fact I am having issues with leaks I think it's best to get a new cover. This is a pain in the butt as it takes ages to get stuff from the US... but what's new.
Offline Gunnytron
« Reply #459 on: September 09, 2018, 12:45:40 PM »
Rad is now at the welders.
I fitted the new front cover, but sanded the casting marks and painted it beforehand. It went quite well until I packed all my tools away and realised I'd forgotten the front cover gasket :banghead:
Still waiting for the ARP Crank bolt.
« Reply #460 on: September 09, 2018, 01:06:43 PM »
On the bright side, at least you haven't installed and torqued the damper.  :P
Offline Gunnytron
« Reply #461 on: September 09, 2018, 01:38:23 PM »
Well, I had. But there was enough wiggle room to slide it in behind.
« Reply #462 on: September 09, 2018, 03:34:16 PM »
Huh?  You said you were still waiting on the damper bolt from ARP..
Offline Gunnytron
« Reply #463 on: September 09, 2018, 03:58:59 PM »
Yeah, but I had put the pulley on and torqued it down with the old bolt.
Offline Gunnytron
« Reply #464 on: September 22, 2018, 12:33:47 PM »
My crank shaft bolt finally turned up, so I put the car back together.
I got the rad back in and, as expected, the fan now overlaps the shroud too much. The two options I have are ditch the shroud or find alternative fans. A dual, low profile fan setup would be nice, but I have no idea which to get (spal aren't readily available over here) and don't really fancy spending the money.
