February 19, 2025, 06:37:41 PM
Author Topic: UK RHD LS1 8.8 FD Gunnytron's build thread  (Read 252056 times)
Offline 1320king
« Reply #180 on: March 30, 2014, 05:47:24 PM »
looks great!!
Offline Gunnytron
« Reply #181 on: April 06, 2014, 01:26:34 PM »
Had a relatively busy week with the car.
Last week I sprayed all the cavities in the bay with Dinitrol rust converter and also filled and painted the holes I made when removing the tunnel brace mount.
I painted the ABS bracket and base along with the bolts. Some of it has gone matt though as it was damp outside. Hopefully a polish will bring it up again.
This weekend I sprayed Dynax S50 in to the cavities, then spent a good 4+ hours going over any seams that were missed by the garage (used epoxy mastic). There's a lot of nooks and crannies which makes it a really tedious job, not to mention messy.
Here's a view in to one of the frame rails:
I still need to figure a way of getting the crap out of the cam sensor hole. I may have to blow it down and take the sump off to clean it out. Not sure how much room there is though.
I got a new rear o-ring for the water pump so that can be prepped for paint now.
« Last Edit: December 09, 2017, 02:00:20 PM by Gunnytron »
Offline Gunnytron
« Reply #182 on: April 12, 2014, 11:26:47 AM »
This took me way, way longer than I expected but glad it's done.
Dei tunnel heat shield
« Last Edit: December 09, 2017, 02:01:39 PM by Gunnytron »
Offline bimbleuk
« Reply #183 on: April 12, 2014, 01:28:03 PM »
Nice job ^^
One half of my tunnel looks like that... the other half I was lazy and kept the Mazda matting.
Offline Gunnytron
« Reply #184 on: April 12, 2014, 02:59:10 PM »
Nice job ^^
Your so lazy :)
If it's any concillation, my hands are ripped to shreds.
Offline Gunnytron
« Reply #185 on: April 12, 2014, 03:14:53 PM »
Next job was to sort out all that crap that fell in the engine when I took the cam sensor out.
Firstly took off the sump. Turns out the sump gasket is shot.
Luckily most of the rubbish fell straight on this
Some grit stuck to the crank shaft.
But, after an hour or so I got it all clean. I looked up under the engine and got in there with an earbud taped to a skewer to reach up inside. I then turned the engine 1/8 turn then repeated the process.
« Last Edit: December 09, 2017, 02:26:37 PM by Gunnytron »
Offline Gunnytron
« Reply #186 on: April 18, 2014, 01:34:03 PM »
After a bit of a faf I got the rear subframe out. It's in a bit of a state and I can't be bothered to spend ages tidying it up so I purchased one that has already been dipped. Hopefully this coming week I will be getting the front diff mount welded in.
I still could do with the height that the standard bushes sit above the subframe mounts. I know that the pinion angle needs to be 2.5 degrees (relative to flat of subframe top), but I want to make sure I have plenty of room to play with.
Also tarted up the ABS pump a bit. I could have done it alot better but fully dismantling it would have been loads of work. Besides, I am not going for a show car finish.
« Last Edit: December 09, 2017, 02:15:55 PM by Gunnytron »
Offline Gunnytron
« Reply #187 on: April 19, 2014, 06:10:40 PM »
Got some surface rust to sort out under here
ARB, tank straps and fuel lines are all a bit crusty here so will get them cleaned up this week
Got the fuel tank out (I was on a roll). This has some rust in too. Going to get some deox gel to sort it.
« Last Edit: December 09, 2017, 02:19:19 PM by Gunnytron »
Offline megatron
« Reply #188 on: April 21, 2014, 05:54:37 AM »
nice work , i need to to get my subframe off to and clean it up lol ,  nice work on the heatshield
Offline Gunnytron
« Reply #189 on: April 26, 2014, 10:50:49 AM »
Got started on the cobra diff mount. This is going to be a lot of trial and error as the car is miles away from where the workshop is.
So far the cross bar has been bent and spot welded so that I can move it about a little. It is sitting quite proud of the subframe at the moment so I suspect it may hit the underside of the car.
I also started making a blanking plate for the clutch master, blasted and painted the brake servo heat shields (not sure if I will be using them), drilled the blanking plate ready for the tapping a 1/8 NPT for the speedhut oil sensor. Blasted the rear anti-roll bar and the fuel tank straps but these need soaking in anti rust as they got surface rust almost instantly.
I also had to file the middle holes on the Samberg batwings. I don't know if I am just unlucky, but that's twice I have had to modify bolt hole locations on Justin's stuff.
The brake lines that run round the rear subframe also need to be remade as they are a bit too corroded. I blasted the line splitter for them though.
« Last Edit: December 09, 2017, 02:21:55 PM by Gunnytron »
Offline Gunnytron
« Reply #190 on: April 28, 2014, 08:24:39 AM »
Bit of a fail on the pipe for the subframe. There's no way it will fit in its current shape as it hits the seat wells.
My next plan is to get some pipe insulation of the nearest size an use that to mockup an alternative.
Offline Gunnytron
« Reply #191 on: May 03, 2014, 02:35:02 PM »
Finished refurbing the water pump, brake servo heat shields and accessory brackets.
« Last Edit: December 09, 2017, 02:27:27 PM by Gunnytron »
« Reply #192 on: May 03, 2014, 04:58:21 PM »
That looks fancy, nice work!
Offline quinns
« Reply #193 on: May 04, 2014, 01:24:53 AM »
Man is it ever tight back by the diff I couldn't imagine having to make that myself. Will be a bit of trial and error I think. Interested to see how it turns out!
1997.5 Hummer H1
2006 Hummer H2 SUT
Offline Gunnytron
« Reply #194 on: May 04, 2014, 03:54:11 AM »
I spent quite some time yesterday trying to figure out the best shape for the mount. I ended up making the frame dog leg each side. I will get pics up of the plastic pipe template if I finish it today.
