March 14, 2025, 07:19:37 AM
Author Topic: Joel's LS1 FC parts list/swap thread (remixed)  (Read 813990 times)
« Reply #165 on: September 19, 2010, 10:44:00 PM »
It's on and painted.  Took a big push to get it done for SevenStock (hence lack of updates).  Pics of install and finished version this week...
« Last Edit: September 19, 2010, 10:57:33 PM by frijolee »
Offline Bigblockquad
« Reply #166 on: September 20, 2010, 12:58:43 AM »
Joel,  yours is easily my favorite FC.  Can't wait for the pics....... :popcorn:
94 RX7 LS7, Racelogic TC (565hp/505tq)
07 Superformance GT40 Dart alloy 427 (548hp/561tq) 2290 lbs...
06 Lexus IS350
04 Chevy 2500HD Diesel, lifted on 20x35's
95 BMW M3 440ci LS7/ T56
« Reply #167 on: September 20, 2010, 12:36:23 PM »
OK, so I posted a bunch of teaser pics of the fender arch work prior to Seven Not Stock Davenport...  In hidesight the only thing I should have done different is to get a set of wheels on the car before trying to take measurements for the cardboard template.  That would have helped be quite a bit more precise.
Oh and if you weld your fenders do everything in 1/2" stitch welds at max.  You really want to spread the heat around as it's easy have things warp and buckle on you.  I was pretty careful and I still had one minor issue.
Now on to the pics!!!
Self etching primer
White rattle can primer and seam sealer (rust prevention)
White gloss paint over the sealer
I shaved the insides of the fenders around the edge to help minimize the transition I would need to bondo...
Prepping the fenders (sharpy marks where to remove paint, holes are because I used cleko clamps throughout the install):
Taking off paint is slow and messy...  Angle grinders and flapper wheels are your friends.
Paint off, everything wiped down with denautured alcohol for maximum adhesion.
Glue applied (3M 8115 panel bond).  You'll need a full 200ml.  Even that is a bit close but I found I could just ration my usage as I went.  The manual applicator gun works fine (see seam sealer pic) I used about 40 3/32" cleko clamps all from an army surplus guy on ebay.
Real tires came in...  Big and beefy that's for sure...  Ain't my daugter gorgeous?
Checking offset and shaving lips for max squat.
Spacers I wanted to run had a smaller OD than the wheel mounting surface (things like that will drive me nuts) so I had some new ones water jet cut.
Long hair filler (AKA kittyhair) to really tie down the edges.  This stuff is weird but it works great for filling gaps and holes.
Starting to rough out the shape.  Low spots are obvious but you want regular bondo for the actual transitions.
« Last Edit: September 29, 2010, 03:52:11 PM by frijolee »
« Reply #168 on: September 20, 2010, 12:36:33 PM »
By comparison the front's are pretty easy.
Added two more clips besides the factory location to help define the line of the door.
Checking full lock steering:
Wide tires gave me more issues fore-aft because of the new arc than they did up and down.  Here's a conflict with the OEM fender duct (shot straight from below).  I'm also running without my washer fluid resevoir for the moment but otherwise it's fine.
Add some good heat and it gets soft...
Then you push it agains something flat (I used the edge of my workbench).
One side down, one to go...  No issues.
Still need to make new fender linings but that's a project for another day...
Mazdaspeed lip?  Cut and splice, glass and bondo...  I was a lot of work but not really hard...  No problem.
There was the start of the proper bondo/smoothing, but this was what she looked like loaded up and getting ready for SNS 2010.
Full pictures of that crazy 4,000 mile trip are here:
http://www.norotors.com/index.php?action=profile;u=50;area=aeva
« Last Edit: October 02, 2010, 11:22:01 AM by frijolee »
« Reply #169 on: September 20, 2010, 12:57:32 PM »
So now comes the fun part...  smoothing it in.  My only real suggestion here is to go slow and use the biggest sanding blocks you can find.  I've screwed myself by trying to force stuff and it only results in low spots.  If you sand too far, add more bondo and keep moving.  I probably have 30 applications of bondo on here...  (In my defense I'm a noob at body work and it was crazy hot in Cali so I usually only had about 2.5 minutes of working time for each application).
The sharpest curvature is rear fenders at the door seam.  I found that using the backside of my rubber block gave a nice consistent radius that was about right.
This is pretty much where I spend my evenings for about three solid weeks (yeah, I'm slow).  Note the long sanding block.
This was where I screwed up and should have had the lower edge pulled 1/4" forward.  So instead I got to cut off the edge closest to the tire and reshape the whole lower portion.  It's a lot of layers of bondo but its maxes out at about 3/16" thick.  The trim detail took quite a while to get looking right.
Setting up the "paint booth" with everything blended in
It's a family affair.  (Wife and Dad)
Mom with the kid.  My EZ up wasn't big enough so I placed it diagonally to shield as much of the car against wind as I could.
Water trap: plastic hose for better thermal conductivity, copper would be better but this still worked really well.
Washed the car, then a denatured wipe down, then a high build primer.  Note there's two schools of thought here.  Some folks prefer gray or dull primers so you know you have enough base coat.  I choose white as insurance just in case my basecoat turned out thin.
Glazing putty / spot filler
Sppt filler sanded out.  You can follow with more primer if you still have low areas (too low and it's back to bondo).
Close up of the holes and scratches this step fills.  It's easy to tell where you went after the fiberglass more aggressively.
Shooting basecoat
Clear
Same basic process went down for the front fenders and lip except these were all painted off board.
Problem with the new shiny bits is that suddenly my doors looked terrible.  I couldn't help myself so I pulled all the hardware and painted those too.   Door handle hardware you get to one bolt with the window up and one bolt with the window down.  I probably took out around 20 door dings between both sides  :punch:
Sanded out the rough stuff at the bottom of the door.
Strangely my doors don't match.  The pass side was hard texture at the base while driver's side had rubberized stuff that had to be scrapped off.  Furthermore the trim on passenger's used solely double stick tape, while driver's side had holes for clips I had to fill (epoxied patch panels on the back and then filled with bondo).
And here's the Ronin crew at SevenStock...
« Last Edit: October 02, 2010, 12:00:29 PM by frijolee »
« Reply #170 on: September 29, 2010, 03:54:10 PM »
Ed note: Bumped this down post so I could have more space up top.
Thanks Rich, your FD is damn high on my list too.  Is the LS7 done?
Here's a few shots of the finished version that I took last night.  Still need to color sand and polish.
Check out those fender lines!   :yay:  :yay:
« Reply #171 on: September 29, 2010, 04:11:23 PM »
Added a bunch of install pics above.
Offline josh18_2k
« Reply #172 on: September 30, 2010, 01:08:01 AM »
is that a JKL wing?  did you make the mounts?
meat is neat
« Reply #173 on: September 30, 2010, 02:50:05 PM »
Wing overall shape is from an OEM RE-Amemiya wing.  It's one of the products pending from Ronin Speedworks.
Changes:
-Mounts have better curvature to match the back deck of the car.
-Mounts are ~2.5" taller than the RE original so it doens't interfer with your rear view.
-Greater range of adjustement relative to angle of attack
-We smoothed the shape of the wing it in a few places and we're using a stronger layup.
-Three attachment points per mount instead of two for better side to side rigidity.
More info coming
« Last Edit: September 30, 2010, 04:25:14 PM by frijolee »
« Reply #174 on: October 02, 2010, 12:03:10 PM »
Added pics of painting process above.
« Reply #175 on: October 02, 2010, 08:40:59 PM »
One of your doors is S4, one is S5.   :)
Thanks for the updates.
Offline project dc2
« Reply #176 on: October 21, 2010, 12:13:42 PM »
did you water jet that front plate ? kinda interested if you have the design i can get it made or sell em ?
« Reply #177 on: October 21, 2010, 01:21:59 PM »
Intake was a total one off inluding the aluminum shroud (there are hot links in the first post if you don't want to dig).  Biggest problem is that MTI is now out of business so if you wanted to replicate the intake you'd have to find one used.
Given how much crap you have to move around (overflow, relays, hood latch, hood prop, hood shocks etc) it's not for most folks.
« Reply #178 on: November 12, 2010, 05:16:11 PM »
Changes:
More info coming
First article for the main wing is complete.   Teaser pic but the RE wing would have split in half if I tried this (it delaminated from normal use on a fast car)...
We'll have full info up on www.roninspeedworks.com.  This and the FD fenders have been sucking up most of our R&D time but at least we're getting close.
« Last Edit: November 12, 2010, 08:10:13 PM by frijolee »
Offline theantirotor
« Reply #179 on: November 12, 2010, 06:26:52 PM »
I would love to see the widebody with trim back on it.  Of course asside from the doors that would be a custom job.
I assume no one really worries about it but couldn't you actually get a ticket for not having side marker lights anymore?
:bacon:
