March 14, 2025, 08:03:25 AM
Author Topic: Joel's LS1 FC parts list/swap thread (remixed)  (Read 814014 times)
Online shainiac
« Reply #570 on: March 13, 2020, 09:03:10 AM »
Joel, If you ever want to make custom ball joints for S4 control arms, 05-10 Mustangs use the same shank diameter as FC RX7s. I believe the undercut for the clamp bolt is a slightly different diameter, but it works. They're press-in with a snap ring, so all you'd need to do is make some steel cups. Whiteline and a few others also make extended versions for bumpsteer correction too. I'm using the same year Mustang knuckles with an OEM FC balljoint with no real modification other than using Mustang coilover lower mounts.
BMW DCT Swap, Ronin 8.8" IRS
« Reply #571 on: March 16, 2020, 06:26:16 PM »
Good tip on the Mustang ball joints.  Do you know if FC and FD are the same?
I take it back, a few more things did happen before we left SoCal.
New O2s (started throwing a check engine light).  Ash (@largeorangefont) and I did a street tune and verified WOT was on the money re: air/fuel ratio.  It still doesn’t like to idle cold though.
Idle issue seems to be related to IAC but it didn't seem to change with the HP Tuners fields we were trying to edit.
Fuel pump hose came loose inside the tank.  Put it back with a fresh hose and made sure both clamps were full tight.
Had a semi throw rock and crack my windshield.  Found another and was able to verify that s4 windshields do work in S5 chassis.  The part numbers are different but I think it’s just the tint.
It was strangely quite emotional watching the Ronin logo head off for the dump.
Ah well, I had the Ronin decal on there for 7 years so it was time for a new one anyways.
Trimmed a bit more rear wheel arch in order to get maximum tire stuff.
Took a couple glamour shots.  The one with the weird light was in the middle of crazy skies following a SoCal fire.  I do not miss So Cal fires.   I am, however, a big fan of meaty rubber.
It's kinda one of those things that you look back at while walking away...   :yay:
« Reply #572 on: March 16, 2020, 10:58:50 PM »
That thing is such a monster.   One of the few cars I don't think I'd change much, if anything on.
« Reply #573 on: March 17, 2020, 03:14:57 PM »
It needs different seats LOL. That's about it.
« Reply #574 on: March 17, 2020, 03:32:22 PM »
Thanks for the kind words, but there's always something.  I'm back running a wing for autocross and if I run it full steep I'm understeering more than I like.  I have some front canards I might add but they're a little ricer so I haven't quite decided.  My seats need reupholstering and I'd love to get a GT width for passenger.  Most folks don't fit in them if they're above about a 36" waist.   I want to get AC back up and fuctional.  Oil cooler thermostat has an oil drip.  Hell, I still have traction control sitting on the shelf that'd be legal in my class.  I have a friend who runs a mean 370z (blown) that makes for some stiff competition.
Biggest issue these days is a hard shifting trans that I haven't quite figured out.  Bleeding clutch didn't solve it.  It makes me want to say screw it and ship out a magnum but we stretched to buy this house so I'm trying to be at least a little conservative with the finances (when I post up some garage progress you'll see where I've been less so).
:secret:
Seems like all my free time goes to Ronin and/or workshop setup these days.  I'm ignoring the weeds in the too large garden as well.  Definitely not complaining but I have to make an effort to get out to autocross or post write ups or such.
« Last Edit: March 17, 2020, 04:45:47 PM by frijolee »
« Reply #575 on: March 17, 2020, 04:01:14 PM »
How is the autox scene on the big island?  Car looks great, and I hate silly fuel issues too.
« Reply #576 on: April 08, 2020, 05:49:16 AM »
Pretty good.  Well run events with interesting layouts.  I'm always impressed how much diversity they come up with running on go-cart track.
Mostly I dig the crew.   We have everything from modern stuff to a classic mini and MG drag car that runs on slicks and skinnies (and no F's given). There's a Lotus Elise that usually contending for fastest time of day.  Anytime I beat him I beat him I'm feeling solid but it's a pretty tall order to honest.  It's hard to get the power down and TC and ABS would be a big help.
Of course it being Hilo, weather is a factor and when it rains hard I'm a complete worthless slip in slide.  The track is about 5.5-6 seconds different dry vs. wet which is pretty much an eternity on a 50 second lap.  I've also discovered that with the wide NT01s, I go in a dead hydroplane at about 50 mph.  Had a few exciting moments on the highway going to an from but I'm trying to build up my go with the flow chill and just be OK doing 45 if needed.
I need to get my fender liners modified and installed.  The hinges pick up a wee bit of crap in the wet.
A buddy got some decent shots at one recently.
Obligatory blurry wheel pics.  Pretty good lines (vs. cones) on a few of these!
Always a good time.
I did throw the wing back on at some point.  Now running one of the last built Ronin carbon GT wings.  Hangs over the bumper a touch which is technically a no-no but no one I run with cares.  I may throw on some front canards to help the balance as I can't go full steep without noticing a change in handling.
Two very different cars that are both rad and both competitive.
On the left is a friend's blown 370z.  He's my most direct competition in class.  Last year I was running XP, but I recently discovered that the rules about engine swaps from a different manufacturer changed in 2018 or so.  It used to be an automatic kick to the prepared classes (hence XP), but now it's a 150 lbs weight penalty on minimum class weights which is meaningless for a full interior car and I can run SSM.
That mild looking 85 civic on the right is a factory AWD that I didn't know existed.  He's on sticky rubber and can drive.  Rad cars, good people both.
Anyways, fun is where you find it and I'm glad to be driving this thing a LOT, even if it is getting dirty with regularity.
Big smile on a day I ran FTD.
« Reply #577 on: April 08, 2020, 09:50:32 AM »
Great stuff! I actually really like the wing. Any videos?
« Reply #578 on: April 08, 2020, 10:16:57 AM »
Good to see your enjoying your car!  Your car looks really good and I love the massive tires.
« Reply #579 on: April 08, 2020, 03:37:29 PM »
Local video blogger did a piece that featured the Lotus and my RX7.  My bit starts at 11:12.  I ended up FTD on this one.  The Lotus kicked my ass after the handicaps were posted (typical).  Episode is called money bags since we all have some coin in our rides...  That is, at least compared to the "dirt bags" amateur circle track guys he hung out with before us.  ;)
« Last Edit: April 08, 2020, 03:44:39 PM by frijolee »
« Reply #580 on: April 09, 2020, 08:22:41 PM »
A little thing but one that I think turned out bitchin'.  Hawaii requires a front license plate.  CA did as well but never enforced this that I know of.  HI on the other hand, checks as part of their annual safety inspection.
Too bad since I like the nose without a plate.
The other challenge I have that my neato mesh grill blocks access to the factory license plate bracket mount point on the bumper cross member.
I really didn't want to drill holes in my shiny--still fairly fresh paint--bumper cover.  Cutting slots in the mesh seams like a lot of work and again, I'm not excited about the holes (or pulling off the whole nose to mount a license plate).  There's also an issue that the front plate is kinda big relative to the shape of the nose so it either blocks the radiator opening or sits up higher than looks natural.  I did a high mount setup slightly angled backward back in CA and it was OK but I was never quite happy with it.
I also wanted to fully support the edges of the plate so it wouldn't bend or deform over time.  That happened to my CA setup too.  After starring it at a bit I decided to try mounting the plate to my SS mesh insert.  No holes and it seems plenty stout.
Bit of use with a surface gauge and I ended up with this CAD template.  Surprisingly skinny once I actually laid it out.
The trick to make this work is that I bent the lower edge of my plate.  This skinnies up the landing on the nose and makes the bottom edge a bunch stiffer.  I have a coworker here in Hawaii running a front plate that he has bent down to nothing but the letters and he's gotten away with it for 5+ years.  I decided to be a bit more subtle and only added a single bend on the lower edge.  There are some regulations about not defacing license plates as government property but I didn't find anything specific about what I did.  Worst case, I have a cop get pissed and I bend it back.
Bar and clamps to bend.  Also some aluminum angle iron and rivet nuts starting to form the top edge.  That got shaved to match the bumper curvature too.
The backside of the framework I formed over and welded (at least partly).  Crustly old aluminum scrap makes for tough welding, but I got it good enough.  Less heat in the rear so the weld looks shitty, sorry.  It's hidden and the front side welding was probably enough.
I also did some whittling in the corners.
Why?  For rubber trim of course!
There is a lower cross bar tucked back there too, so 4x rev nuts and the result is well supported on all sides.  4x zip ties per side hold it on (because you gotta have a little redundancy when relying on zip ties.)
The result:
It's as tight at I could get it while keeping the cross section at the sides reasonable and maybe it clears the bumper by 1/4" or so in the middle of the plate.  I like proportionally it just fits a hell of a lot better on the nose, but it's still subtle enough with the mods that's it's not in your face.  No one caught it my autocross shots so think I did a good job of getting it right and being sly about the mod.
It's the kinda stuff that's changed--but you almost can't figure out why since it looks so right--that gets me excited these days.  Bitchin' eh?
« Last Edit: April 09, 2020, 08:41:15 PM by frijolee »
« Reply #581 on: April 09, 2020, 08:29:44 PM »
That is one properly over-thought and over-engineered plate setup and I freaking love it.    You’re a man after my own heart Joel, haha.
« Reply #582 on: April 09, 2020, 08:38:21 PM »
Thank you sir...  I thought you might like this one.
It's the kinda stuff that's changed--but you almost can't figure out why since it looks so right--that gets me excited these days...
Exhibit A) Blake's Mustang.   :cheers:
« Reply #583 on: April 09, 2020, 09:41:47 PM »
Here's what I did for a front plate on my 99 Miata.
I got pulled over once for no front plate, and when I told the cop it was there, he walked around to the front and stood there with a dumb look on his face. LOL
[attach=1]
« Reply #584 on: April 10, 2020, 04:59:09 PM »
That's funny.  I've seen the crazy articulated flippy plates, but I don't really want the weight of the mechanism or any such.  I'm good enough with what I built that I'm just leaving it alone now.  Random thought, but does it matter if we blur plate numbers on the internet these days?  I always have, but yesterday's write up was the first time it was kinda a pain in the ass.
