March 14, 2025, 08:31:32 PM
Author Topic: Joel's LS1 FC parts list/swap thread (remixed)  (Read 814157 times)
« Reply #300 on: August 26, 2013, 08:31:30 PM »
Awwwwwwwww snap!  Joel's going hog-wild with headers!
Excited to see where this goes :)
« Reply #301 on: September 04, 2013, 12:17:49 AM »
Pretty much.  Hell, it was what?  8+ months ago when I first called to pick your brain on this?  Doing this a little different than most.
I've been referring to this to friends as a "paint by numbers" headers build since I'm working direct from a spreadsheet.  I'm 100% sure you could do this faster, but if I was going to do this, I at least wanted to make it as good as I was able to justify the effort.
There's a few radii bigger than normal headers in my design...  Daddy's little helper.
First time using a tube shrinker/stretcher.  Works well for getting that last bit of perfect alignment since all my bends are about 0.030" in the bent section vs the straights.  Scrap aluminum is just a striking point up top.
For comparison... Taper at the top
vs taper at the bottom
Also in a tight bend, compare the material thicknesses at the top of the bend vs the bottom.  2" CLR bends at about twice as noticable as 3" CLR bends.
These merges make me smile every time I look in the end.
PS Note to self, keep extra band saw blades on hand.  It was super late and my spare cheap backup blade wasn't doing anything but get dull on stainless, so I kept cutting on this guy WAY longer than I should have.  The difference the next day with a new blade was stupid.
« Last Edit: September 04, 2013, 12:25:59 AM by frijolee »
« Reply #302 on: September 04, 2013, 01:11:33 AM »
Hnnnnnnnnnggggggg, pants just got tight.  Excellent lookin' stuff.
Unrelated:  left you a VM on your cell today ~ when you get a chance, hit me back!
Offline SOB Racing
« Reply #303 on: September 04, 2013, 12:33:07 PM »
can you post a picture of the tubing stretcher without the pipe...i can't visualize what happening there.
1985 944 Pending a 4g63T Swap
1992 Eagle Talon TSI Retired
12.27 @ 111 on 14B
12.27 @ 113.9 on Small !6g
2006 HHR "The Hearse" Lowered
« Reply #304 on: September 04, 2013, 11:56:28 PM »
No problem.  It's just a cast steel cone that you can hammer pipe onto (or into) and get a very minor taper.  Use the outside to stretch.  Use the inside to shrink.   Props to Anthony (v8-rx7) for turning me onto the tool.
Only problem I found is that when I have large angles to the bends there's really nothing to hammer (picture trying to stretch one end of a 90 deg bend, there's just nothing to strike since the end isn't in line).  You can kind of do a two handed tomahawk blow just grasping the bend by hand and swinging the bend downward but it most just gets it closer to round and won't really stretch.  I found just squishing with the vice was easier to take out a bit of oval if I had any...
If anyone else has used these and knows a better technique let me know (I'm making this up as I go).  That said, for what I'm doing it seems to do a decent job.
Offline SOB Racing
« Reply #305 on: September 05, 2013, 12:14:59 PM »
I want one...where did you get it?
12.27 @ 111 on 14B
« Reply #306 on: September 05, 2013, 12:21:21 PM »
giant magnets.
sorry, i've used a homemade one of these on aluminum before. and never had a good idea on that part.
« Reply #307 on: September 05, 2013, 04:23:00 PM »
Lisle 32000.  Been a while, so I can't remember where I picked it up.  Looks like the usual suspects have it though...
http://www.summitracing.com/parts/lil-32000
http://www.amazon.com/Lisle-32000-Pipe-End-Shaper/dp/B0002STSO4
Works on 1.5 to 3.5 tubing
Offline SOB Racing
« Reply #308 on: September 05, 2013, 10:33:10 PM »
thanks!
12.27 @ 111 on 14B
« Reply #309 on: September 09, 2013, 06:07:43 PM »
Just a few progress shots from over the weekend.
« Last Edit: September 10, 2013, 02:00:46 PM by frijolee »
« Reply #310 on: September 09, 2013, 06:13:54 PM »
Oooooooh weeeeee.
Lookin good!   :cheers:
« Reply #311 on: September 09, 2013, 07:39:31 PM »
That's good progress!!
I have a pretty good local coating hook up if you want to get them thermal coated Joel.
Offline Bowtie7
« Reply #312 on: September 09, 2013, 08:05:41 PM »
That dryer is gonna sound sweet with those pipes. Clothes will dry much quicker too! Looking great Joel!!
I do love what I do!
« Reply #313 on: September 10, 2013, 01:36:45 PM »
Nice Charlie,
Thanks all,
I'm relatively excited by the design, but damn I hope they work well given all the effort that's going into these.
Header Design Notes
A couple key differences and the though process why I didn't just by JTR 1 7/8 (assuming I could have talked Mike into making me a set):
-All stainless steel, including flanges.  Flanges came from Extreme Perfomance Sandcars (http://stores.ebay.com/Extreme-Performance-Sandcars?_trksid=p2047675.l2563 or (909)887-8000) and are 1/2" thick but also use a design tucked quite tight to the bolt pattern.  All bends came from Performance Tube Bending (www.performancetubebending.com) which had by far the best prices I found anywhere and also happened to be relatively local; they're just up the street from Jordan Innovations.
-Big bends.  7 of the 8 primaries use 3" CLR bends coming off the headers instead of the more typical 2 or 2.5 CLR bends.  The big bends in the body are 6" CLR, nested against 4" CLR.  The whole thing was designed in CAD so tangencies are very good (some of the JTR joints are 5+ degrees off).
-True equal length headers looked about impossible to package without massive body cutting but I'm at least closer than other readily available options in terms of getting both the length I want and lengths as close to each other as possible.  David Vizard's point that it's "more important to have lengths correct than to have lengths equal but wrong" makes a lot of sense to me.
-Merges came from Burns Stainless and ran about $400 each (more than my last headers did!).  I justified the expense because Burns runs analysis software with every merge order to spit out an "optomized" header design.  That was a helpful validation of the research I'd been doing.  Plus it's fun with Jack Burns (legend) turns out to be this kindly grandfatherly figure who's makes googley eyes at my 3YO daughter and makes her giggle.
-Probably the biggest single debate I had was whether to run with Burns recommendation on primary sizing.  I finallly did but I struggled since pipes too big is at least as bad--if not worse than--pipes too small...  I was curious it anyone would spot it in the pictures but in case you didn't, these headers o' mine are 1.875 -> 2.0" stepped headers.  Engine is a 429 ci but they're still massive compared to what I'm used to.
-Bonus good news.  Passenger looks like it will install from below (something I was concerned about, having no real way to check that in advance). I have a few minor rubbing points but they're mightly close to fitting how I want and I think I can adjust what I have to work.  Driver I haven't checked yet but I knew I'd be clearancing floorboards to keep ground clearance already so I'm less worried about that.
Anyways, that's the philosophy.  Brismo7 stopped by and took a mug shot for me...  Gives a better idea of scale.
What do you think?  Too much or just right for a 429?  I'm more or less committed at this point.
« Last Edit: September 10, 2013, 03:17:43 PM by frijolee »
« Reply #314 on: September 10, 2013, 01:57:20 PM »
PS...  The steps are staggered to occur at specific lengths too!
