March 15, 2025, 03:33:26 AM
Author Topic: 4G63 FD  (Read 30110 times)
Offline Bean4g63
Re: 4G63 FD
« Reply #15 on: July 22, 2012, 10:45:07 PM »
How much does an engine + transmission combo like yours goes for? I am curious.
I used the RX7 trans that came with the car and made an adapter plate.  As for the motor, you can pick them up from a junkyard for $500-$700.  The stock motors will handle 450-550whp without an issue.  Anything over that and you need rods/pistons.  You can get away with just putting cams and valve springs/retainers in the head.  If you do the work yourself you can have a pretty stout bottom end for $2300-$3000.
Offline WannaBeFast
  • Single and Looking
Re: 4G63 FD
« Reply #16 on: July 23, 2012, 12:21:45 AM »
Quote
Ok thanks. I want a light tube chassis 4 banger in the future, and this motor is def a candidate. i used to have a 420A lol with a rigged up turbo kit - just after the first Fast and Furious lol.
Offline fearnopiston
Re: 4G63 FD
« Reply #17 on: July 24, 2012, 12:36:39 AM »
cool to see something different, nice work!
-Chance
Offline forcefed86
Re: 4G63 FD
« Reply #18 on: July 24, 2012, 10:45:10 AM »
Looks fun, ever take it ot the track?  Those are some mighty expensive parts for 520whp, plan on turning it up? :poke: My daily driven talon just trapped 124 the other weekend. Amazing little motors for sure.
Offline SpendOne
Re: 4G63 FD
« Reply #19 on: July 24, 2012, 06:15:52 PM »
Seen you made your way over here Bean.
Stock 350 block/iron headed/nitrous/93 pump gas junker
melted piston....best of 6.07 1/8  9.57 1/4
Higher compression SBC 406 now
Changed again...Stock turboed LQ4 8.79@154mph SOLD
Offline Bean4g63
Re: 4G63 FD
« Reply #20 on: July 25, 2012, 09:53:48 AM »
124mph is cute.  My daily driven Talon was doing that 12yrs ago.   :poke: :D  I dont plan on going to the track until the end of the year.  Still have to make a rear diff brace and a trans brace for it.  Once I stop being lazy and fix the knock sensor I will turn it up on straight pump gas and leave it at 560-600whp.  I will consider E85 if it becomes readily available around here.  When I do take it to the track it will be exactly how I drive it on the street, regualr street tires, pump gas, etc.
Offline Bean4g63
Re: 4G63 FD
« Reply #21 on: July 25, 2012, 09:54:45 AM »
Sure did.  This is a great site with good info.
Offline SpendOne
Re: 4G63 FD
« Reply #22 on: July 25, 2012, 04:28:22 PM »
There is a few of us ex-4g63 guys on this forum.
Offline N2v8fcs
Re: 4G63 FD
« Reply #23 on: August 15, 2012, 06:03:08 PM »
nice work !
:drive:
Offline Bean4g63
Re: 4G63 FD
« Reply #24 on: September 01, 2012, 02:49:15 PM »
Finally got my rims.  Rears are 17x10 and fronts are 17x9.
Offline nadeem
Re: 4G63 FD
« Reply #25 on: September 01, 2012, 04:00:23 PM »
Excellent work and a joy to read this post.  Do upload more pictures.
Offline Bean4g63
Re: 4G63 FD
« Reply #26 on: January 05, 2013, 12:31:17 PM »
Put the car back on the dyno for a retune.  The car made 571whp/376ft-lbs on straight pump gas (93 octane).  Cant wait for the warm weather to put the power to the ground.
Offline babillaracing
Re: 4G63 FD
« Reply #27 on: January 05, 2013, 12:54:36 PM »
very nice and original build
Offline turbotalon1g
Re: 4G63 FD
« Reply #28 on: January 05, 2013, 01:34:49 PM »
Love the color. :drool:
Nice setup, a local with that turbo made 745whp on a DD, I think that's over 800whp DJ.
Not my choice of motor, but they are stout. Also had a local run 600whp thru his stock bottom end for over a year 10k miles, lots of stock bottom ends trapping 140s in full weight ish cars, not tin cans.
Would love to see this in person. location?
Offline Bean4g63
Re: 4G63 FD
« Reply #29 on: January 05, 2013, 02:25:05 PM »
Thanks, its a killer turbo that can make around 800whp on E85 and lots of boost.  They make 550-600whp on pump gas pretty easily.  I'm in NJ.
