March 18, 2025, 02:47:59 AM
Author Topic: LS1 RX-7 rebuild/build 4l80e, Ronin 8.8 and turbo  (Read 38920 times)
Offline stbrn19
Re: LS1 RX-7 rebuild/build 4l80e, Ronin 8.8 and turbo
« Reply #90 on: April 26, 2014, 04:00:13 AM »
Yeah I made all of it with out properly test fitting the bumper.  I have a stock bumper not a 99.  I Had to dent the pipe a bit near the intercooler to clear the indicator in the front bumper on the driver side.  It's not pretty but it'll function fine.
Played around with some stuff tried to tie up some loose ends in the engine bay.  You can kind of see my awesome clearancing of the IC pipe in this pic
« Last Edit: April 26, 2014, 04:08:47 AM by stbrn19 »
Offline stbrn19
« Reply #91 on: April 28, 2014, 05:30:20 AM »
Been trying to tie up some little loose ends in the engine bay.
Got my radiator hoses sorted out and got some fancy hose clamps:
Mounted my solenoid for my boost controller and ran lines for the wastegate and solenoid:
Mounted my Trans cooler and ran lines:
Engine bay is coming together, slowly chipping away at the long list of stuff to do.
« Reply #92 on: April 28, 2014, 08:55:28 AM »
Welding is coming along. Looks good
Offline N2v8fcs
« Reply #93 on: April 28, 2014, 02:10:49 PM »
why did you take out the solid rear?
:drive:
Offline stbrn19
« Reply #94 on: April 28, 2014, 05:19:23 PM »
Have two swapped fd projects. This one will be the more mild of the two. So I opted to save the solid axle for the more drag car oriented, bigger power setup.
Offline stbrn19
« Reply #95 on: April 28, 2014, 05:20:55 PM »
Thanks man
« Reply #96 on: April 28, 2014, 09:49:14 PM »
when will this beast be up and running?  Gonna be a good summer
Offline Tictakman
« Reply #97 on: April 28, 2014, 09:56:45 PM »
where did you get the little u hose for the coolant heater location??  I need to do the same on my swap
Offline stbrn19
« Reply #98 on: April 29, 2014, 12:04:35 AM »
Autozone should have it. Dayco # 87629
Offline stbrn19
« Reply #99 on: April 29, 2014, 12:09:27 AM »
Not sure. It could run soon. Just need to stop getting carried away tinkering with little crap.   I have been saying maybe a month this whole year. Realistically I could have it ready to fire tomorrow.   I have been trying to do all the little things that will bother me so I don't have to take it apart right away.  It'll probably take me a few more weeks. Then I'll have to get with my tuner and get in line
Offline stbrn19
« Reply #100 on: April 29, 2014, 01:31:00 AM »
inb4 starts a new project.
It's possible. But I have been trying to stay focused until this one runs again.
Offline Tictakman
« Reply #101 on: April 29, 2014, 07:29:13 AM »
Thanks.  You will like that vertical flow ic, I used the same one.  If you want even more response go to an air to water setup.
Z
Offline stbrn19
« Reply #102 on: April 29, 2014, 03:06:52 PM »
Z
I was really close to pulling the trigger on a air to water intercooler. I really wanted to try out this vertical core and after going back and forth I ended up with a vertical core air to air. Hope it works well. With your setup did it hold you back or did it work pretty well?
Offline stbrn19
« Reply #103 on: May 04, 2014, 04:41:18 AM »
F**K push lock lines, (not the push to connect lines on my wastegate) the trans lines kept kinking when I tried to route to the cooler.  Any bends in the line to route them would make the line collapse at least partially.  I remade them using PTFE and they work now...  Had to get a few fittings but I had the line and a fitting left over from the fuel lines.
The lines have high temp sleeves on them until they exit the engine bay.
Offline stbrn19
« Reply #104 on: May 10, 2014, 05:43:09 AM »
Ok, made some progress.  Fixed a few brake lines I had made a few years ago that had questionable flares, replaced my tee fitting with the proper one and bled the brakes.
Installed the rest of the coilovers and put wheels on the car.  It's been a long time now but this thing is ready to be back on the ground rolling around. possibly be able to move under its own power soon as well.
Welded a -10 bung on my drivers side valve cover, got some fitting and a breather can, mounted the catch can near the drivers side headlight:
Installed coils, plugs, wires, and wire heat protector boots.
Did some wiring for the fuel pump but still have a bit more to do there.  Made the new power wire needed to power the mazda chassis and threw in a battery to start testing a few things, have power at the ignition circuit like it should so thats a bonus.  Wired in a few things for the powertrain harness.  Need to add wiring for the reverse lights and the tcc brake circuit.  Also need to verify the rest of the chassis and front harness wiring to make sure its all getting power as it should.
Here are a few shots of the engine bay from earlier today:
