March 18, 2025, 04:04:40 AM
Author Topic: LS1 RX-7 rebuild/build 4l80e, Ronin 8.8 and turbo  (Read 38923 times)
Offline stbrn19
« on: July 19, 2012, 02:39:12 AM »
So a lot has changed in the past year.  I have two turbo ls based rx7 builds.  The newest edition despite my best efforts still needs some love.  I decided I was not going to be happy with it unless I tore it all down and started over improving upon it (there were tons of things that drove me crazy or just didn't work).  Also the New (light blue car) is just rough inside;  Needs new interior trim, has a shitty roll cage needs all new chassis wiring, the turbo kit is a pile of shit, the motor is on its way out the door, etc.
Long story short I decided to swap over the usable parts of the build into my other chassis and give the rough car the "racecar" treatment.  So here we are
Plans in the immediate future are;
Engine:
forged LQ4, JE pistons, k1 rods, stock crank
Modified hinson single turbo kit
243's with ARP studs
LS6 Intake w/ ported throttle body
Cam motion custom (baby cam) for turbo
Drivetrain:
Beefed up 4l80e
Billet converter with a ~3000-3200 stall
Solid 8.8 axle conversion
Redo the turbo kit using a Hinson hotiside kit and just go from there
I'm leaving the other build information for reference to anyone it may benefit and moving in this new direction.
« Last Edit: April 19, 2014, 03:39:45 AM by stbrn19 »
Offline stbrn19
Re: LS1 RX-7 rebuild/build
« Reply #1 on: July 19, 2012, 02:40:28 AM »
Here are a few old pics of how the car once was:
Havent decided how crazy I want to go with weight reduction.  Leaning towards keeping the interior and at least a basic stereo..
Offline stbrn19
« Reply #2 on: July 20, 2012, 08:47:20 PM »
In preperation for the lizard skin that ill be applying I started working on removing some factory stuff.
Made some more progress,  working on removing the factory sound deadening...
Still have a bit more around the transmission tunnel but I was out of dry ice and over working on it in the 105 degree heat
More to come
Offline stbrn19
« Reply #3 on: September 23, 2012, 03:56:36 AM »
Some parts and some progress:
Trans stuff
Lizard Skin
Pulled the harness out to change a few things and clean it up
Mostly back together
Stuff no longer needed
Offline stbrn19
« Reply #4 on: September 23, 2012, 04:02:08 AM »
Got my 8.8 kit from Justin and started working
QA1 coils for the rear
Fitting the subframe in the car
Testing the fitment on the wheels
Going to get some wheel spacers to push the wheels out a bit
Offline stbrn19
« Reply #5 on: September 23, 2012, 04:04:28 AM »
So started on the interior with alot of help from ray.. thanks bud :thank_you2:
Having an extra set of hands to mask everything off was priceless
Started by striping everything remaining out of the interior except for part of the harness which I wrapped up to protect it.
Then realized I only bought the heat insulation from lizard skin :suicide:
So ended up doing a mass loading rubberized coating as a base which the heat product will go on top of.
Went to work
Sprayed pretty much everything, floor pan, doors, roof, hatch, everything I could get to
Now need to wait for this stuff to dry then start spraying the heat insulator :laugh:
Then I have some more sound deadening crap to go on top that is very light weight and orders some new black carpet since mine is done.
More to come...
Offline stbrn19
« Reply #6 on: September 23, 2012, 04:05:31 AM »
So kept working and applied the first coat of Lizard Skin CI
Some close ups.  It looked like a very fine spray on bed liner when I was cleaning up but felt pretty soft may change as it finishs drying
Going to take a look at it tomorrow and decide if I feel like doing another coat.  It shouldn't need it since I already made two passes and laid it on pretty thick.
« Reply #7 on: September 23, 2012, 09:59:19 AM »
Looking good sir.   :)
Offline dregg100
« Reply #8 on: September 23, 2012, 10:55:25 AM »
Ohhh heroo Rich, didnt recognize the screen name!
Offline stbrn19
« Reply #9 on: September 23, 2012, 03:50:43 PM »
Offline stbrn19
« Reply #10 on: September 23, 2012, 03:51:25 PM »
Sup bud  :wave:
Offline screamin88
« Reply #11 on: September 23, 2012, 07:14:34 PM »
Subscribed..  :yay:
Offline stbrn19
« Reply #12 on: September 23, 2012, 11:44:29 PM »
Worked on the car for a while today, didn't feel like doing anymore prep and masking...
Was thinking about skipping doing the engine bay but ultimately it made sense to do it all now.  The bay is beat up and paint was flaking off in a few places pretty beat and weathered.
So started prepping the bay and masking.. blah
Sprayed the bay with some high temp flat black paint.  Did two coats.
Very happy with how it turned glad I didn't get lazy
The rest of the time I spent dicking around with the interior and putting a few pieces back in.  Got the headliner and sunroof stuff in, sun visors, and put most of the back plastics back in.
Laid out some crap
Offline stbrn19
« Reply #13 on: September 28, 2012, 12:07:00 AM »
More progress, waiting on my new carpet to arrive. Needed to finish up all the sound deadening in order to be all ready to start on the carpet when it shows up (hopefully tomorrow)
So far I did a mass loading rubberized coating, then Lizard Skin the last step before the carpet (which also has a backing product on it) was another product by Raamaudio called Ensolite which is a sound deadening and heat isolator which is also fire retardant.
Big thing is Its very light so you can go crazy with it without it weighing down too much.
So began the slow and painstaking process of trying to get 100% coverage on all the interior where the carpet and dash / pain to remove stuff will be.
Start
first door was a little shaky never used this product before...
Second door
Starting the dash
Making progress
All of the car forward of the rear bins done
Ran out of stuff even though I bought more than the "recommended" amount for a small car, need a bunch more to finish but at least I did all the stuff that the carpet will cover.
Started making/modifying my brake lines for an ABS delete, going to see how it turns out before I deiced 100 percent if I want to eliminate it.
Alos started finishing up extending the Harness to relocate the pcm from the passenger kick pannel area.  Need to extend about 10 more hours and pretty it up.
Offline stbrn19
« Reply #14 on: September 29, 2012, 07:27:47 AM »
So today got some speakers in the mail, along with my new motha fuckin carpet.  Couldn't have been happier about it either.  Went out and started tinkering with the speakers and fumbling with their mounting (for way too long) then did this.  The speakers are some fairly nice infinity's that should run well of an aftermarket deck.
Put in the factory firewall sound deadening blanket, then moved on the the carpet, its a cheap carpet that IS molded but you have to cut all the mounting holds and accesses.  Did not think it would have been such a pain but it was... Now its done.
Started doing this, cutting some backing to level out the mountainous floor pan design.
Kept doing that and triming until the carpet laid nice on it and then began the process of trying to cut holes for everything, seat mounting, restraints, etc there was a bunch of crap to do.  Took my time and kept chugging along.
Then fought with the dash for a while
Started trimming the overage of the carpet around the edges and finally called it a night, hands are raw and my back was pissed from hunching and contorting in the car a bunch again
more soon.
